Brad V Posted October 23, 2013 Share Posted October 23, 2013 I am getting back into Civil design after an extended layoff and I'm learning Civil 3d on the job/ also on my own. Hopefully that will explain what may be a very simple question. I just created a proposed surface using a point group. When I started labeling the contours I noticed they are 1 foot lower than they should be. I checked some spot elevations and I found this consistent across the site. Is there a setting that would have caused the surface to be created 1 foot lower than the proposed points? Thanks for any help. Quote Link to comment Share on other sites More sharing options...
Organic Posted October 26, 2013 Share Posted October 26, 2013 See http://docs.autodesk.com/CIVIL/2010/ENU/AutoCAD%20Civil%202010%20User%20Documentation/index.html?url=WS27101fef35e777f9aeffdffbf5418ea8-7f02-procedure.htm,topicNumber=d0e79853 Quote Link to comment Share on other sites More sharing options...
Brad V Posted October 28, 2013 Author Share Posted October 28, 2013 Thanks for the response. I ended up deleting and recreating the surface, this time it was correct. My concern wasn't so much how to raise the surface but why using only the points I entered would it be created a foot too low. Oh well, live and learn. Next time I'll verify the surface is correct before I calculate my earthwork. On first glance the proposed contours looked like what I expected so I didn't label them. Quote Link to comment Share on other sites More sharing options...
