LT 2014 Sheet Set Manger Scale
Is there a way that I can have the scale update itself from the viewport on that specific sheet in the project.
Thank you
Can you elaborate? Did it have to do with opening that sheet and saving?
In the Field dialog, change Field Category to Objects, Field Names to Object, Object Type use the Select button to select your Viewport, the select the desired property.
Thanks for the answer. I asked because I may be installing 2014 LT in a few days. Appreciated.
