Ok, I am going to see if I can explain this.
I have a block that we use often (it's a connector block), and I have already completed the Single Lines with said block. Now the client wants an additional piece of information that I would need to add as an additional attribute to this block.
This block is dynamic, with a visibility and a flip parameter, and two attributes, Line# and Cable/Panel.
I'm going into BEDIT for the block, adding an attribute, and deleting the Cable/Panel Attribute to make room for the new att. When I exit out of the Block Editor, the new attribute doesn't exist, and the Cable/Panel attribute is still there. What's really weird is that the Cable/Panel att used to be in the flip parameter, and now it's not. It stays when you flip the block.
Does anyone know what could be causing this? I'm starting to think this is just a ghost in the machine! But I've restarted AC, restarted the Computer... nothing helps.
Maybe you need the attsync command. I haven't used that on dynamic blocks however.
Yup... that worked. I've never had to use that command before! Thanks!
