isutheparambil Posted October 28, 2013 Posted October 28, 2013 hi, i am facing a problem while insert an object from other drawing to an existing dwg., but the inserted contents are not visible. the layers all r on position, insunits set it to 4, the inserted object layers all set it to 0 layer, no use. even insert as a block also no use. if anybody have an idea to solve this, pl. let me know Quote
isutheparambil Posted October 28, 2013 Author Posted October 28, 2013 yes i done z-e, z-v everything Quote
ReMark Posted October 28, 2013 Posted October 28, 2013 What version of AutoCAD was the other drawing made with? Could it be there is a clipping plane involved here? Quote
isutheparambil Posted October 28, 2013 Author Posted October 28, 2013 all using 2012, save all as 2010 and the thing even i cant see if i insert as a block, i can see or edit by block editor command, then that mode i can see. but when i save and close the block editor, it will disappear. pl. can u explain about clipping.. i didnt get that Quote
ReMark Posted October 28, 2013 Posted October 28, 2013 Attach a copy of the drawing to your next post. Was the drawing made in-house or did it come from someone outside your company? Quote
isutheparambil Posted October 28, 2013 Author Posted October 28, 2013 that all created in my office itself by different people (CAD) just take a while, i ll attach the dwg, after binding. Quote
isutheparambil Posted October 28, 2013 Author Posted October 28, 2013 and also that is a huge file let me try, if it s possible to send, i can. Quote
ReMark Posted October 28, 2013 Posted October 28, 2013 Are you using xrefs? Could the layer be frozen? Quote
isutheparambil Posted October 28, 2013 Author Posted October 28, 2013 yes there is 20 different service files i attached as xref also all layers are on there is no any layers freez, off, or lock nw i m trying to bind tht to send u bu i cant sent , cz i s too big file Quote
