ADT2009,
I have a project with several sheets. Is there an option to insert the sheet list from my Sheet tab in Project Navigator into my DWG? Thanks!
ADT2009,
can you clarify a little more? I am having a hard time understanding :)
and I would like to insert a list with this sheets names (as a table) to my title Dwg. and of course if this list can be updated whenever I add a sheet it will be great. THANKS!
ok, after fiddling around with it, I think I have something for you.
It involves fields.
1. type in Field in the command line, it will open a list of stuffs.
2. Under "field Category:" change it to "SheetSet"
3. in the "Field Names:" area look down until you see "SheetSet" and select it.
4. under "Sheet Navigation tree:" it will list your sheets that are setup in the project.
5. select the sheet you wish to insert the information for, and click ok, it will prompt you to pick a point where you want that info. If the text has grey around it, it is ok, it is just showing you that it is a field, and wont plot.
you will have to enter each one individually, but they will update if you change anything about the individual sheets. Seems pretty nifty, and I may start using this type of information as well.
Field does work! the only thing is that if I want more then one property to shown (Sheet Name, Sheet Description, Sheet Number etc.) then I will have to make it with my on table. But it's Great - Thanks again!
you are more than welcome :)
