link between layout tab, file name and text string by lisp
Hi folks
Is there any way to link between layout tab,file name and text string by lisp?
To rename layout tab to file name:
(defun c:ltdn (/)
 (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object))))
 (vlax-for l (vla-get-layouts *AcadDoc*)
   (if (eq 1 (vla-get-taborder l))
     (vl-catch-all-apply (function vla-put-name) (list l (vl-filename-base (getvar 'dwgname))))
Do you need to insert file name somewhere in drawing in text format?
Mostafa more info please. 3 different variables add all together and label layout ?
Hi, all
I want linked between all of them when I change file name automatically change
layout tab and text string
Use field for text but for layout you should use lisp for that see the link in post #4
mdbdesign
I am waiting for your reply
Good, wait...
My suggestion is:
-use rtext (Diesel) for text string, it is old but working like a horse
$(substr,$(getvar,dwgname),1,$(-,$(strlen,$(getvar,dwgname)),4))
For changing layout tab need to create button with lisp codes or just type lisp command call and update it manually whenever change file name.
Unless somebody will write reactor to do it.
