samifox Posted October 30, 2013 Posted October 30, 2013 hi have my first dcl (defun C:Test(/ fname lname age dialogLoaded dialogShow dcl_id ) ;; extract the values (setq fname (cdr (assoc 42 getDiaVal)) lname (cdr (assoc 43 getDiaVal)) age (cdr (assoc 3 getDiaVal)) ) (alert (strcat "your first name is " fname "your last name is " lname "your age is " age ) ) ) (defun getDiaVal(/ fname lname age dialogLoaded dialogShow dcl_id) ;define defult value for text box (setq fname "first name" lname "last name" age "0" dialogLoaded T dialogShow T ) ;; Load the DCL file. (if (= -1 (setq dcl_id (load_dialog "simple.dcl"))) (progn ;; There's a problem - display a message and set the ;; dialogLoaded flag to nil (princ "\nERROR: Cannot load gpdialog.dcl") (setq dialogLoaded nil) ) ;_ end of progn ) ;_ end of if ;; Load the dialog box (if (and dialogLoaded (not (new_dialog "simple_dcl" dcl_id)) ) ;_ end of and (progn ;; There's a problem... (princ "\nERROR: Cannot show dialog gp_mainDialog") (setq dialogShow nil) ) ;_ end of progn ) ;_ end of if ;initilizing defualt values (if (and dialogLoaded dialogShow) (progn ;; Set the initial state of the tiles (set_tile "fname" fname) (set_tile "lname" lname) (set_tile "age" age) ) ) ;; invoke the dialog. (start_dialog) ;; OK or cancel has been hit, you're out of the dialog. Unload it (unload_dialog dcl_id) ;; Build the resulting data (if UserClick (progn (setq Result (list (cons 42 fname) (cons 43 lname) (cons 3 age) ) ;_ end of list ) ;_ end of setq ) ;_ end of progn ) ;_ end of if ;assign action to tiles (action_tile "accept" (strcat "(progn (setq fname (get_tile \"fname\")))" "(setq lname (get_tile \"lname\")))" "(setq age (get_tile \"age\")))" "(done_dialog) (setq UserClick T))" ) ;_ end of strcat ) ;_ end of action tile Result ) simple_dcl : dialog { label = "My First DCL"; // the labal on the blue bar initial_focus = "fname"; // what box get the fucus first spacer; : row { fixed_width = true; : column { width = 30; //fixed_width = true; spacer; : text { label = "First Name"; } } : edit_box { key = "fname"; edit_width = 20; //fixed_width = true; } } : row { fixed_width = true; : column { width = 30; //fixed_width = true; spacer; : text { label = "Last Name"; } } : edit_box { key = "lname"; edit_width = 20; //fixed_width = true; } } : row { fixed_width = true; : column { width = 30; //fixed_width = true; spacer; : text { label = "Age"; } } : edit_box { key = "age"; edit_width = 20; //fixed_width = true; } } : row { // defines the OK/Cancel button row : spacer { width = 1; } : button { // defines the OK button label = "OK"; is_default = true; key = "accept"; width = 8; //fixed_width = true; } : button { // defines the Cancel button label = "Cancel"; is_cancel = true; key = "cancel"; width = 8; //fixed_width = true; } : spacer { width = 1;} } } get this error ; error: bad argument type: listp # cant figure out Thanks S Quote
MSasu Posted October 30, 2013 Posted October 30, 2013 At a glance, the definition for getDiaVal is placed after is called; there may be some other issues, I didn't went deeper in your code. Quote
MSasu Posted October 30, 2013 Posted October 30, 2013 Some other issues: There is a line that should be commented: (setq Result (list (cons 42 fname) (cons 43 lname) (cons 3 age) ) ;_ [color=red];end of list[/color] ) ;_ end of setq Similar comment issue + Verify that there are some extra closing paranthesis on the action_tile: (action_tile "accept" (strcat "(progn (setq fname (get_tile \"fname\"))[color=red][s])[/s][/color][color=#000000]"[/color] "(setq lname (get_tile \"lname\"))[color=#ff0000][s])[/s][/color][color=#000000]"[/color] "(setq age (get_tile \"age\"))[color=#ff0000][s])[/s][/color][color=#000000]"[/color] "(done_dialog) (setq UserClick T))" ) ;_ end [color=red];of strcat[/color] ) ;_ end of action tile The getDiaVal is a function, cannot be called like a variable: (setq fname (cdr (assoc 42 [color=red]([/color]getDiaVal[color=red])[/color])) Also please pay attention that you are calling the dialog three times in a row! You attempted to build a associative list with the result of dialog, but I'm afraid that that code isn't reachable after you call done_dialog. I would let the dialog read function variables to visible at main's function level instead (where are declared local anyway): (defun getDiaVal( / [color=red];fname lname age dialogLoaded dialogShow dcl_id[/color] ) There are also some issues with the formatting of your DCL definition - check that you have some broken comments and labels; also there is an un-supported "button row" keyword and a floating "button" one. Quote
ymg3 Posted October 30, 2013 Posted October 30, 2013 Samifox, Cause of the errors is you are calling a subroutine, you need to put it in between parenthesis (getdiaval). Please format your code a little when you post. Very difficult to help you. Sorry, about that MSasu did not see your reply. We were posting at the same time. ;; extract the values (setq fname (cdr (assoc 42 (getdiaval))) lname (cdr (assoc 43 (getdiaval))) age (cdr (assoc 3 (getdiaval))) ) Quote
samifox Posted October 30, 2013 Author Posted October 30, 2013 Thanks you all guys the final working code drived from your comments (defun getDiaVal(/ fname lname age dialogLoaded dialogShow dcl_id) ;define defult value for text box (setq fname "first name" lname "last name" age "0" dialogLoaded T dialogShow T ) ;; Load the DCL file. (if (= -1 (setq dcl_id (load_dialog "simple.dcl"))) (progn ;; There's a problem - display a message and set the ;; dialogLoaded flag to nil (princ "\nERROR: Cannot load simple_dcl.dcl") (setq dialogLoaded nil) ) ;_ end of progn ) ;_ end of if ;; Load the dialog box (if (and dialogLoaded (not (new_dialog "simple_dcl" dcl_id)) ) ;_ end of and (progn ;; There's a problem... (princ "\nERROR: Cannot show dialog gp_mainDialog") (setq dialogShow nil) ) ;_ end of progn ) ;_ end of if ;initilizing defualt values (if (and dialogLoaded dialogShow) (progn ;; Set the initial state of the tiles (set_tile "fname" fname) (set_tile "lname" lname) (set_tile "age" age) ) ) ;assign action to tiles (action_tile "cancel" "(done_dialog) (setq UserClick nil)") (action_tile "accept" (strcat "(progn (setq fname (get_tile \"fname\"))" "(setq lname (get_tile \"lname\"))" "(setq age (get_tile \"age\"))" "(done_dialog) (setq UserClick T))" ) ;_ end of strcat ) ;_ end of action tile ;; invoke the dialog. (start_dialog) ;; OK or cancel has been hit, you're out of the dialog. Unload it (unload_dialog dcl_id) ;; Build the resulting data (if UserClick (progn (setq Result (list (cons 42 fname) (cons 43 lname) (cons 3 age) ) ;_ end of list ) ;_ end of setq ) ;_ end of progn ) ;_ end of if Result ) (defun C:Test(/ fname lname age dialogLoaded dialogShow dcl_id ) ;; extract the values (setq diare (getDiaVal)) (setq fname (cdr (assoc 42 diare)) lname (cdr (assoc 43 diare)) age (cdr (assoc 3 diare)) ) (alert (strcat "your first name is " fname "," "your last name is " lname "," "your age is " age "." ) ) ) simple_dcl : dialog { label = "My First DCL"; initial_focus = "fname"; spacer; : row { fixed_width = true; : column { width = 30; fixed_width = true; spacer; : text { label = "First Name"; } } : edit_box { key = "fname"; edit_width = 20; fixed_width = true; } } : row { fixed_width = true; : column { width = 30; fixed_width = true; spacer; : text { label = "Last Name"; } } : edit_box { key = "lname"; edit_width = 20; fixed_width = true; } } : row { fixed_width = true; : column { width = 30; fixed_width = true; spacer; : text { label = "Age"; } } : edit_box { key = "age"; edit_width = 20; fixed_width = true; } } : row { : spacer { width = 1; } : button { label = "OK"; is_default = true; key = "accept"; width = 8; fixed_width = true; } : button { label = "Cancel"; is_cancel = true; key = "cancel"; width = 8; fixed_width = true; } : spacer { width = 1;} } } Quote
