PotGuy Posted October 30, 2013 Posted October 30, 2013 Hey all, just a quick one. What was the command to increase the amount of viewports that were active in one paper space tab? Currently hit the default limit. Quote
Tyke Posted October 30, 2013 Posted October 30, 2013 Try MAXACTVP. It's saved in the drawing not the registry so it appertains only for the current drawing. Quote
Tyke Posted October 30, 2013 Posted October 30, 2013 Man Dadgad you were quick off the mark there I'm not sure if there is a maximum value, although as the value is an integer it would have a theoretical maximum of 32767 if they are using 16 bit integers. Quote
Tyke Posted October 30, 2013 Posted October 30, 2013 The max is 64. You are right again ReMark. Did you know that or did you look it up? Quote
PotGuy Posted October 30, 2013 Author Posted October 30, 2013 I can second what Remark said. When in putting the command, when I put in 80, for example, it will state a value the value must be between 2 to 64. Quote
ReMark Posted October 30, 2013 Posted October 30, 2013 I knew the max number but I also double checked before posting it. Quote
