legio Posted November 2, 2013 Posted November 2, 2013 I can not solve the problem . i have interference in elbow ( left side ) . p/s part in sheet metal Quote
Lazer Posted November 18, 2013 Posted November 18, 2013 Looks like yo have modelled this as a standard .itp using surfaces then added a thickness to each surface?. I would have used sheetmetal using contour roll for this. Quote
legio Posted November 18, 2013 Author Posted November 18, 2013 hi. when will you collect parts. you will have a penetration between the parts. and the problem is thicker.you cfn use contur roll but it is not real material . Quote
JD Mather Posted November 18, 2013 Posted November 18, 2013 I would not use Contoured Roll for this. Attach your file(s) here for instruction on correct technique. Quote
legio Posted November 19, 2013 Author Posted November 19, 2013 hi / i have 2 more . and i go way 2.ipt 1.ipt Quote
