akyassin Posted November 7, 2013 Posted November 7, 2013 Please my friend, I have a master file which i will attach as Xref to 50 sheets. I am connecting ECW image as a background in the master file but it is not appearing in the son files (file where i am attaching the master file). Is there any way to do that and let it appear to avoid connect this image in each sheet separately. Thank you for cooperation. Quote
BlackBox Posted November 7, 2013 Posted November 7, 2013 ECW works just fine with Civil 3D... How did you attach this image to your master drawing? MAPIINSERT Command? More information is needed. Quote
akyassin Posted November 7, 2013 Author Posted November 7, 2013 Thank you for response. I am. Attaching the image by MAPWSPACE command , connect data. Of raster image Quote
BlackBox Posted November 7, 2013 Posted November 7, 2013 If the ECW raster does not correctly reference through to sheet drawings using Task Pane, what happens when you instead use MAPIINSERT Command? Quote
akyassin Posted November 8, 2013 Author Posted November 8, 2013 If the ECW raster does not correctly reference through to sheet drawings using Task Pane, what happens when you instead use MAPIINSERT Command? Thank you very much Black Box, this problem was solved by your way but i faced another problem related to the previous: When i am inserting he image to the master file every thing is OK. but when i am opening the sheets i found the Image on top of all other xref in spite of the image order is bottom off all in master file. What do you ink teacher ?? Quote
