I have a SSM set up with both Sheet Custom Properties and Sheet Set Custom Properties.
When I start a new project, i can populate both areas of the main SSM.
I'll create my sheets and have them self populated by the "root" SSM settings (if you will)
well now, lets say i need to change the date of the sheets from the past.. to the future submittal date. I set it in the "Sheet Custom Properties" in the "root" SSM and then I have to go to each sheet; right click --> Properties each sheet and change the custom properties.
Basically, is there a way to have the sheets (after created) to automatically update to the new date?
Am i missing something?
