PEGAdevelopment Posted November 8, 2013 Posted November 8, 2013 I have these pink circles on my corridor when in isometric view. How do I turn them off? Quote
Organic Posted November 9, 2013 Posted November 9, 2013 Click your corridor and in the properties change the code set style to something else (just try a couple etc until you find one you like). If you want to permanently fix the issue for that particular code set style, then select the assembly and edit the code styles in there. My guess is that the marker points are set to be relative to your screen size since they are so big. Quote
