mwade93 Posted November 8, 2013 Posted November 8, 2013 The code that I posted works perfectly for me every time so you should not have any issues. Make sure to check out that code i posted a couple posts up. Quote
Diesel Posted November 11, 2013 Author Posted November 11, 2013 The code that I posted works perfectly for me every time so you should not have any issues. Make sure to check out that code i posted a couple posts up. Could you post that code one last time MWade. Thanks Quote
Tuns Posted November 12, 2013 Posted November 12, 2013 Could you post that code one last time MWade. Thanks See post #6 for the code that he is referring to... Or it could be post #19... Not entirely sure. Quote
Diesel Posted November 14, 2013 Author Posted November 14, 2013 Does anyone know what I need to do to fix this error: ^C^C(setvar “cecolor” “ByLayer”) (setvar “celweight” -1) (setvar “celtype” “ByLayer”) Command: (setvar “celtype” “ByLayer”) ; error: bad argument type: (or stringp symbolp): nil Quote
Tuns Posted November 14, 2013 Posted November 14, 2013 Don't use setvar. That should fix it. Why not just use one of the macros that mwade and I posted? Quote
Diesel Posted November 14, 2013 Author Posted November 14, 2013 Don't use setvar. That should fix it. Why not just use one of the macros that mwade and I posted? I'm not sure what his do. I am very new at this. What should I use besides setvar. All I want is to change all layers back to the default color is all. Any help would be great. Thank you Quote
Tuns Posted November 14, 2013 Posted November 14, 2013 setvar isn't really needed when setting a system variable. All you need is the system variable name like this: cecolor;"ByLayer”; Try to use semi colons instead of spaces so that your macro is easier to read. Also, you don't need quotation marks around command names. Quote
mwade93 Posted November 16, 2013 Posted November 16, 2013 Sorry, I got moved over to a new area and I don't really have the time to sit on this site as everyone piles work on me now. But tuns is right about not using setvar. Quote
