tekla model to autocad 3d model
hello there, i dont know if it is already on the old thread but seems it is not yet, is any one there knows regarding convertion from tekla model to autocad 3d model, as in you can also rotate the view in autocad 3d model.
thanks in advance. . .
What file formats does Tekla save to and/or export to? That's would be good to know don't you think?
Found this online. For the remainder of the instructions click on the link below.
You can export models to 3D DWG or 3D DXF file types. By default, Tekla Structures creates a model.dwg file in the current model folder.
To create a 3D DWG or DXF export file:
  1. Open a Tekla Structures model.
  2. Select File > Export > 3D DWG/DXF... to open the Export 3D DWG/DXF dialog box.
http://teklastructures.support.tekla.com/191/en/int_exporting_3d_dwg_dxf
FYI - Industry Standards
There are many industry standard file transfer formats. The principle ones supported by Tekla Structures are IFC, CIS/2, DSTV, SDNF, DGN, DXF, DWG, IGES, and STEP. Older formats are also included. For a tighter integration, you can link to Tekla Structures using the Tekla Open API technology.
Edited by ReMark
