ismiflori Posted November 15, 2013 Posted November 15, 2013 How can i stretch an inserted image as ole obj with different dimension of x & y. i tried stretching it but its width and length is the same, can't properly put it in a specified area in my working space.. help,.. tnx.. Quote
Dana W Posted November 15, 2013 Posted November 15, 2013 Copy the image to the block editor and save it as a block. Then you can give the block different x, and y scale factors as you insert the image as a block, or you can scale the block with different x, and y factors after it is inserted. Quote
SLW210 Posted November 15, 2013 Posted November 15, 2013 Select the Image>Right-Click>Properties go to Geometry>Lock Aspect and select NO. Quote
Dana W Posted November 15, 2013 Posted November 15, 2013 Select the Image>Right-Click>Properties go to Geometry>Lock Aspect and select NO.Well, that's easier. I tried looking for something like that in 2014 trial version and must have missed it, or can't do it in the LT version. I'm gonna go look again. EDIT: Just looked. The Lock Aspect option is not available in the Geometry properties in the LT version of AutoCad 2014, but it probably is available in the OP's 2007 full. Quote
SLW210 Posted November 15, 2013 Posted November 15, 2013 Well, that's easier. I tried looking for something like that in 2014 trial version and must have missed it, or can't do it in the LT version. I'm gonna go look again. EDIT: Just looked. The Lock Aspect option is not available in the Geometry properties in the LT version of AutoCad 2014, but it probably is available in the OP's 2007 full. Yes, LT has limit functionality with images. AFAIK, it should work in 2007 Full. Alternatively, you could do this in an Image Editor. Quote
ismiflori Posted November 20, 2013 Author Posted November 20, 2013 Select the Image>Right-Click>Properties go to Geometry>Lock Aspect and select NO. thanks a lot dude.. this one really helps.. this process works also in 2013 version? Quote
