sukhbirsingh91 Posted November 19, 2013 Posted November 19, 2013 How to use the vertical scale and the horizontal scale in autocad 2012? Quote
MSasu Posted November 19, 2013 Posted November 19, 2013 Welcome to the Forum, sukhbirsingh91! What do you mean by "scale"? Are those the scale factors of blocks, something related to you industry standards or the scroll bars? Also, please try to use a relevant title for you threads. Quote
sukhbirsingh91 Posted November 19, 2013 Author Posted November 19, 2013 existing site plan plate 2.dwgI need to do the civil drafting .. am attaching the images .. please guide me to do the project.. Quote
MSasu Posted November 19, 2013 Posted November 19, 2013 So, seems that you want to represent something using different scale factors on X, respectively Y. Although someone working in the same field may suggest a better approach, one solution will be to draw everything 1:1, create a block of you sketch when done and insert it using the said scale factors on x, respectively Y. Quote
ReMark Posted November 19, 2013 Posted November 19, 2013 (edited) I'm guessing that image was reproduced from the instructional PDF that goes to a Penn-Foster AutoCAD course and you are working on one of the civil projects. Is that correct? Addendum OK, I did take a look at your drawing and as expected it is the Ocean Avenue civil project section of the Penn-Foster AutoCAD course. This project has been covered in detail in the AutoCAD Beginners' Area > Student Project Questions subforum. A search of CADTutor for 'Ocean Avenue' or 'civil project' should result in a list of similar threads. I know of at least one thread that should be helpful to you as it includes images provided by forum member Car5858. Edited November 19, 2013 by ReMark Quote
