ALoock Posted November 20, 2013 Posted November 20, 2013 Hi there. I want to know if it is possible that a ctb file can change the font in my print. I am working in ProjectWise and using Interplot I created a ctb file to do color mapping. The color mapping worked fine but it then changed my font from a font_iso to something unknown (in screenshot - hope it attached ). I just want to rule out the posibililty that it is / is not a setting from the ctb file. I am actually working with other drawing programs also on this project (MicroStation) but the problem only started when I used the ctb file and not with the MicroStation plot functions. Thanks Quote
MSasu Posted November 20, 2013 Posted November 20, 2013 Please clarify, are you using Bentley MicroStation or AutoCAD? Quote
ALoock Posted November 20, 2013 Author Posted November 20, 2013 In this example I am printing a dgn with a ctb file. Quote
MSasu Posted November 20, 2013 Posted November 20, 2013 I'm afraid that this didn't answer my question. I'm looking for the application you are encounterig issues with. Is that Bentley MicroStation or AutoCAD? Your profile and the sub-forum where the thread is posted say AutoCAD, but the content of your post suggest in fact Bentley MicroStation. So, one that will attempt to provide a solution must know what you were using. Quote
ReMark Posted November 20, 2013 Posted November 20, 2013 Most likely the drawing was originally created in Microstation then either exported to or saved as a DWG file which ALoock is editing and printing using AutoCAD 2010. No, a CTB file cannot change a font. There has to be another reason why you are seeing a difference. Quote
