Remove Only Alphabetical Characters from String
Is there an easy way to do this? I am trying to use vl-string-left-trim to remove all characters that are either a letter or a symbol. I am able to remove them as long as I know everything that will ever be in this string, but I don't know if I always will. I would rather have a safety net that would catch anything just in case it changes.
  • Replies 26
  • ksperopoulos
    9
  • Tharwat
    8
  • Lee Mac
    5
  • pBe
    2
Use vl-string->list to convert the string to a list of ASCII character codes, and then use vl-remove-if with an appropriate predicate function to process this list, removing those codes which do not meet your criteria, before using vl-list->string to convert the resulting list of ASCII codes back to a string.
Here is an ASCII character code reference.
Lee what about your parse numbers.lsp but with ascii values set to be non numbers as an example of method.
Lee Mac - thank you for the response. I tried a similar method to what you are suggesting earlier today with no success. I got the ascii codes returned after running vl-string->list but when I try to use vl-remove-if, I get an error stating "bad argument type for compare". I know it is probably somehow linked to a mistake I am making trying to get the value to return "T" but my brain is fried. I think my searches are leading me down the right path on how to do things, but my inexperience keeps me from moving very quickly in that direction. I will pick this back up tomorrow.
An example ...
(vl-list->string (vl-remove-if (function (lambda (u) (or (< 64 u 91) (< 96 u 123)))) (vl-string->list "Abcd12345XwZ")))
Edited by Tharwat
Thanks Marko
Look into highlighted number, Tharwat...
(vl-list->string (vl-remove-if (function (lambda (u) (or (< 64 u 91) (< [highlight]96[/highlight] u 123)))) (vl-string->list "Abcd12345XwZ")))
Thanks Marko for the correction , Appreciated a lot .
An example ...
Why not?
(vl-list->string
     (vl-remove-if-[b]not[/b]
(function (lambda (u) [b](< 47 u 58)[/b]))
(vl-string->list str)
Vanilla
(defun numbers1 (str / a b)
 (setq a "")
 (repeat (strlen str)
   (if	(< 47 (ascii (setq b (substr str 1 1))) 58)
     (setq a (strcat a b))
   (setq str (substr str 2))
 a
(defun numbers2 (str / a b)
     (setq a (cons b a))
 (apply 'strcat (reverse a))
Why not?
Another ... 8)
(mapcar 'vl-list->string
       (list (vl-remove-if
               '(lambda (u)
                  (not (member u '(48 49 50 51 52 53 54 55 56 57))
               (vl-string->list "Abcd12345X7789wZ")
That certainly provides another route for the OP to consider.
Though, I'm not entirely sure of the desired result, i.e. whether the OP wishes to retain only integers or also retain hyphens & periods and hence decimal numbers also.
Vanilla
Nice one pBe :thumbsup:
Here is a recursive alternative:
(defun numbers ( s / c )
   (cond
       (   (wcmatch s "~*#*") "")
       (   (zerop (setq c (ascii s))) s)
       (   (< 47 c 58) (strcat (chr c) (numbers (substr s 2))))
       (   (numbers (substr s 2)))
Another ... 8)
       (list (vl-remove-if
               '(lambda (u)
I don't understand why you are using mapcar here?
It just seems redundant as you seem to be constructing a list for the sole purpose of using mapcar in the code, which will then return a list rather than a string...
Because the return of the (list (vl-remove-if ..... would be a list , and I know it is a little bit long one so we can shorten it to this without brackets all around as the previous one of course .
(vl-list->string
 (vl-remove-if
   '(lambda (u)
Exactly my point - the code is constructing an unnecessary list, and then processing this single-item list using mapcar - both the list and mapcar are entirely redundant as you have shown with the code in your next post.
The way Tharwat shows with all the ascii codes listed is the path I started down, but when I got to lambda, my brain couldn't fit anything else in for the day. I drank a couple beers, lost a few brain cells, and am back at it again today. Hopefully it will stick. Thanks for all the suggestions!
BTW - I am looking at keeping all numbers and a period.
(vl-list->string
 (vl-remove-if
   '(lambda (u)
      (not (member u '([color=blue]32[/color] 48 49 50 51 52 53 54 55 56 57))
Just by adding the number 32 would take care of the period factor :D
Wouldn't the ascii code be 46, not 32?
If you are talking about the decimal point , then you are right but if it is a free space it should be 32 .
Sorry, decimal point (period) is what I meant. Thanks for clarifying.
You're welcome .
Does lambda need more than one argument. I keep getting an error that says there are too few arguments?
