rengised Posted November 27, 2008 Posted November 27, 2008 Hi everyone, i have a drawing in autocad 2008 is it possible to convert it JPEG file in good resolution? Thanks Quote
succu8us Posted November 27, 2008 Posted November 27, 2008 what you are using when converting to jpeg? im just using jpgout and sometimes Print Screen button its fine with me. Quote
rengised Posted November 27, 2008 Author Posted November 27, 2008 Thanks for the reply succ8us i used both, jpgout is not clear when i print it. Any other way? Thanks again Quote
dbroada Posted November 27, 2008 Posted November 27, 2008 I have a JPG "printer" set up. I havbe quite a low res set as I used it for creating pictures in a forum but I am sure you can set the resolution in the properties button. Plotter Manger|Add a Plotter and choose Raster File Format as your manufacturer. Quote
mugshot Posted November 27, 2008 Posted November 27, 2008 try looking for this.... swf printer pro, download the software and install, this ones were used in our office... got a problem like you do... but do not use it for pdf file... so crapy..... Quote
manhattan Posted November 27, 2008 Posted November 27, 2008 you could export as a pdf. open the pdf in photoshop and save as a jpg (if you have PS at work of course) Quote
ReMark Posted November 27, 2008 Posted November 27, 2008 A bit more involved but you could save your AutoCAD drawing in .bmp file format. Then open up the drawing in MS Paint and immediately save it as a .jpg file. Quote
rkmcswain Posted November 28, 2008 Posted November 28, 2008 Hi everyone, i have a drawing in autocad 2008 is it possible to convert it JPEG file in good resolution? Thanks JPG is generally a poor choice for vector drawings. See also: http://www.dotsoft.com/procedures.htm#PlotToRaster Quote
rustysilo Posted November 28, 2008 Posted November 28, 2008 Jpg is fine so long as you set up the print size properly. CADTutor has a tutorial on this and it has been covered many a time in the forum. Check the similar threads at the bottom of the page. This thread might be of service to you. I do usually prefer png when using graphics in general though. Quote
Caranarq Posted November 29, 2008 Posted November 29, 2008 Just copy whichever entities you want to export, then open Power Point (I don't know why this does not work With excel or word), choose Paste special then paste as wnhaced metafile. Once pasted in Power point you can paste it in word o excel. That keeps the resolution for pasting autocad images into office documents. Hope this helps Quote
macareewall Posted February 12, 2009 Posted February 12, 2009 Hi everyone, i have a drawing in autocad 2008 is it possible to convert it JPEG file in good resolution? Thanks Take a look at this thread :http://www.cadtutor.net/forum/showthread.php?t=32278 hope this help! Quote
