keiths Posted November 21, 2013 Posted November 21, 2013 Hi, i need advice on how to insert a PS file in to a DWG... Quote
MSasu Posted November 21, 2013 Posted November 21, 2013 What do you mean by "PS"? Is about Post Script format? According to this, you can convert it to a PDF, a format that you may insert easily into AutoCAD using PDFATTACH command. Quote
keiths Posted November 21, 2013 Author Posted November 21, 2013 Hi thanks, i have attached as a pdf, how do i remove the outline box from around the image... Quote
MSasu Posted November 21, 2013 Posted November 21, 2013 Please set the PDFFRAME system variable to 0. Quote
keiths Posted November 21, 2013 Author Posted November 21, 2013 that works great.. thanks... Can i convert the image to a block, i want to be able to produce a spreadsheet to count and list the blocks to simplify Quote
MSasu Posted November 21, 2013 Posted November 21, 2013 You're welcome! Unfortunatley I don't know if you can create a block out of an image or PDF and don't have AutoCAD right now to test. Let's hope someone will be able to give you a solution soon. Quote
Organic Posted November 22, 2013 Posted November 22, 2013 You're welcome! Unfortunatley I don't know if you can create a block out of an image or PDF and don't have AutoCAD right now to test. Let's hope someone will be able to give you a solution soon. Yes, you can indeed makes blocks out of images & pdfs. Quote
