Viewport Match Properties
I work with many different layers and have several pages with viewports containing different layers frozen and on. Is there a way to match properties on one viewport that will copy the layers onto another existing viewport? Yes, I know I can copy the entire viewport and do as needed, but the are not always showing the same place on the model, necessitating unlocking and moving the view.
Not a big deal, but I figure one of the brains on this forum will know. They have answered everything else! :)
AutoCAD LT 2014, Windows 7 Ultra, quad core duo blah, blah...
You should be able to. Start the MATCHPROP command and hit "S" for Settings, and make sure the Viewport items are checked.
You can't use that between layouts though.
