notview Posted November 22, 2013 Posted November 22, 2013 I'm task to find subsequent vertices of polyline with the same coordinates or zero distance and remove the one vertex. Having thousand corners of lot is not easy to scroll on the polyline properties. Seek for help to anybody to make a lisp to find the TWO VERTEX WITH ZERO DISTANCE and delete or remove the other one. And ask whether Encircle or not the point. May ask to encircle it just to give us a marker where I should start editing of the corner label. Any help would be greatly appreciated. Quote
marko_ribar Posted November 22, 2013 Posted November 22, 2013 Not to search www, I'll dig something from my library that's related to this task... It just relates on removing duplicate vertices, but not encircing them - for this, you have to make the codes be adequate to your specific request, witch is IMO unneccessary... Regards, M.R. HTH Clean_polys.lsp Quote
notview Posted November 22, 2013 Author Posted November 22, 2013 :)It really help!! Thank you M.R. for sharing.. I only ask circle just to give me some clue where to start the correction of my label cause vertices labeled equally to the vertex number. But this lisp is ok, it will remove trouble of my work.. Quote
pBe Posted November 23, 2013 Posted November 23, 2013 (edited) Chocolate (defun c:remseg (/ ss pts_ pts i before after bd dup) ;;; pBe 23Nov2013 ;;; [color="blue"](setvar 'pdmode 34)[/color] (if (setq pts_ nil ss (ssget "_:L" '((0 . "LWPOLYLINE"))) ) (repeat (setq i (sslength ss)) (setq pts_ nil [color="blue"]dup nil[/color] pl (vlax-ename->vla-object (ssname ss (setq i (1- i)))) ) (setq before (/ (length (setq pts (Vlax-get pl 'Coordinates)) ) 2 ) ) (while pts (setq pts_ (cons (list (car pts) (cadr pts)) pts_) pts (cddr pts) ) ) (while pts_ (setq pts (cons (car pts_) pts) [color="blue"] bf (length pts_)[/color] pts_ (vl-remove (car pts_) pts_) ) [color="blue"](if (> (- bf (length pts_) ) 1) (setq dup (cons (car pts) dup)))[/color] ) (setq after (length pts)) (vlax-put pl 'Coordinates (apply 'append pts)) (if (> before after) [color="blue"](progn (foreach p dup (entmakex (list (cons 0 "POINT") (cons 10 p))))[/color] (princ (Strcat "\nBefore: " (itoa before) "\tAfter : " (itoa after) ) ) ) (princ "\n<<No Duplicates found>>") ) ) ) (princ) ) (vl-load-com) Edited November 26, 2013 by pBe Add Marker via points entity Quote
notview Posted November 25, 2013 Author Posted November 25, 2013 Good for cleaning polyline. Thanx.. my only problem of this are the before and after. Did not match to the location of duplicate vertex. Quote
pBe Posted November 26, 2013 Posted November 26, 2013 Good for cleaning polyline. Thanx.. my only problem of this are the before and after. Did not match to the location of duplicate vertex. Not sure what you mean notview, the before and after prints is to show how many "points" it has before and after processing. DO you really want to put a marker on the location? Quote
notview Posted November 26, 2013 Author Posted November 26, 2013 Yes, that is what I really want the marker where the duplicate vertex found. Thank you for the explanation of before and after, I thought that was the location of vertex. Quote
pBe Posted November 26, 2013 Posted November 26, 2013 Yes, that is what I really want the marker where the duplicate vertex found. Code at post #4 updated [For now i used a "point" entity for a marker]. Still don't get the reasoning for the marker though. Quote
notview Posted November 27, 2013 Author Posted November 27, 2013 Thank you pBe, I will try the code.. Quote
notview Posted November 27, 2013 Author Posted November 27, 2013 Cheers!!! It works perfect!! You are greatly appreciated!! Quote
notview Posted December 13, 2013 Author Posted December 13, 2013 pBe, I found something not ok.. I will show it in a figure.. Quote
notview Posted December 14, 2013 Author Posted December 14, 2013 Can you make some changes, I want the result RESULT B. Quote
notview Posted December 20, 2013 Author Posted December 20, 2013 Can anybody help.. I want the result of RESULT B figure. Quote
Stefan BMR Posted December 20, 2013 Posted December 20, 2013 Overkill command removes duplicate vertices. Quote
pBe Posted December 20, 2013 Posted December 20, 2013 Can anybody help.. I want the result of RESULT B figure. Post that particular pline NotView, Maybe an isolated case or maybe not. Overkill command removes duplicate vertices. I didn't know that.. Goes to show you how much time i spent working on CAD nowadays Quote
notview Posted December 21, 2013 Author Posted December 21, 2013 You may check this pline pBe.. Thank you for the time you spent with this thread!! Right BMR, thanks!, OVERKILL can also remove duplicate vertices. I can suggest pBe, you may check the output of overkill with the said sample pline, and that's the correct I want. But still needed the guide points of the position of duplicate vertices, after the removed of that duplicate vertices. Quote
