nguyendan81985 Posted December 2, 2013 Posted December 2, 2013 hi all i have exsample Mtext code as below, but i dont know how to change the Font for this MText. if you know please help me. thanks Sub AddMtext() Dim MTextObj As AcadMText Dim point(0 To 2) As Double Dim width As Double Dim text As String point(0) = 0#: point(1) = 10#: point(2) = 0# width = 10 text = "ABC" Set MTextObj = ThisDrawing.ModelSpace.AddMText(point, width, text) ZoomAll End Sub Quote
fixo Posted December 2, 2013 Posted December 2, 2013 You may want to use mtext formatting see quick example: Option Explicit Sub Example_AddMtext() ' This example creates an MText object in model space ' and align it to bottom center Dim MTextObj As AcadMText Dim pickPt Dim corner(0 To 2) As Double Dim width As Double Dim txtheight As Double Dim font As String font = "Comic Sans MS" Dim text As String pickPt = ThisDrawing.Utility.GetPoint(, vbCrLf & "Pick text position: ") corner(0) = pickPt(0): corner(1) = pickPt(1): corner(2) = 0# txtheight = ThisDrawing.GetVariable("textsize") text = "This is a mtext string with\Pusing " & """" & font & """" & " font" Dim wid As Variant wid = Split(text, "\P", -1, vbTextCompare) text = "\A;\f" & font & "|b1|i1|c0|p0;" & text width = Len(CStr(wid(0))) * txtheight * 0.875 '' Creates the mtext Object Set MTextObj = ThisDrawing.ModelSpace.AddMText(corner, width, text) '' align to bottom center MTextObj.AttachmentPoint = acAttachmentPointBottomCenter '' reset position MTextObj.InsertionPoint = corner Dim minExt As Variant Dim maxExt As Variant ' Return the bounding box for the line and return the minimum ' and maximum extents of the box in the minExt and maxExt variables. MTextObj.GetBoundingBox minExt, maxExt width = maxExt(0) - minExt(0) MTextObj.width = width End Sub Quote
