JoshD818 Posted December 3, 2013 Posted December 3, 2013 I am having difficulty changed the tolerance font colour from the default green to black. I have tried adding "\C##" as a suffix to the dimension style which isn't doing anything. Does anyone know of another way to change the colour? Thanks Quote
Dadgad Posted December 3, 2013 Posted December 3, 2013 Welcome to CADTutor. I don't believe you will be able to do that within the context of a single dimension style, as TEXT COLOR is used across all the tabs of the DIMSTYLE, controlled by the TEXT tab defined color. There may be a way with lisp, but not out of the box, that I know of. Quote
JoshD818 Posted December 3, 2013 Author Posted December 3, 2013 All good, managed to find a way in the end. AMOPTIONS > double click ISO > Settings > Dimensioning > Change layer AM_6 to black Quote
Dadgad Posted December 3, 2013 Posted December 3, 2013 Glad you were able to figure it out, good work! If you are using a Vertical Product, you might want to change your profile software description from Autocad Vanilla. Quote
