Lisp routine offset line and change colour same distance repeat
Hi Guys,
I've got a job where I'm offsetting heaps of lines and I need to change the colour of the line I offset from the colour it was, and I have to keep repeating this over and over.
Is there a LISP routine out there that can offset at a specific distances, change the colour of the offset line and then repeat?
I can't seem to find one out there that does this specifically, and my programming abilities are minimal.
You need to find a offseting routine first then to change colour you need to do a simple "chprop last" this example will change to 1 colour if you want a rainbow look at 2nd version
; offset code ..........
; offsets a line
(command "chprop" "L" '' "C" 140 "")
; code again
;2nd version
(setq x 10)
; code ...............
; offsets a line
(command "chprop" "L" '' "C" x "")
(setq x (+ x 10))
; code again...........
Im not clear on that one, repeat? offsetting an object with the same distance without selecting another object?
Prompt for distance? or a specific color for a specific distance?
It is as easy as what Bigal's suggested, but you need to be more clear on the parameters.
TRY THIS :-
Dont forget to change color code as per your requirement....
(DEFUN C:TEST (/ A B C)
 (VL-LOAD-COM)
 (WHILE
   (SETQ A (CAR (ENTSEL "\nSelect Line to Offset :")))
    (INITGET 1)
    (SETQ B (GETDIST "\nSpecify Offset Distance :"))
    (SETQ C (GETPOINT "\nSpecify Point on Side to Offset :"))
    (VLA-OFFSET
      (VLAX-ENAME->VLA-OBJECT A)
      (POINTSIDE A C)
    (VLA-PUT-COLOR (VLAX-ENAME->VLA-OBJECT (ENTLAST)) [b][color=red]1[/color][/b])   [color=red][b] ;<- SPECIFY COLOR CODE HERE[/b][/color]
 (PRINC)
(DEFUN POINTSIDE (OBJ PNT / P1 PA P2)
 (SETQ    P1 (VLAX-CURVE-GETCLOSESTPOINTTO OBJ (TRANS PNT 1 0))
   PA (VLAX-CURVE-GETPARAMATPOINT OBJ P1)
 (IF (EQUAL '(0.0 0.0 0.0)
        (VLAX-CURVE-GETSECONDDERIV OBJ PA)
        1e-8
   (SETQ P1 (VLAX-CURVE-GETPOINTATPARAM OBJ (FIX PA))
     P2 (VLAX-CURVE-GETPOINTATPARAM OBJ (1+ (FIX PA)))
   (SETQ P2 (MAPCAR '+ P1 (VLAX-CURVE-GETFIRSTDERIV OBJ PA)))
 (IF (MINUSP (SIN (- (ANGLE P1 PNT) (ANGLE P2 PNT))))
   (SETQ B (- B))
   (SETQ B (+ B))
I guess some forum members cant wait for confirmation :)
Try this:
(defun c:ocl ( / ob pt)
 (if (setq color (acad_colordlg
	    (if	color color 7
	    ) nil ))
 (setq dist (cond
         ((getdist (strcat
              "\nEnter Distance [Enter to accept: <"
              (rtos (setq dist (abs (getvar 'Offsetdist))) 2 2)
         (dist)
     (command "_.Offset" dist)
     (while (> (getvar "CMDACTIVE") 0)
(if (and (setq ob (car (entsel "\nSelect object to offset")))
	 (setq pt (getpoint "\nSelect object to offset"))
  (progn (command ob pt)
	 (vla-put-color (vlax-ename->vla-object (entlast)) color)
  (command "")
Danthecadman, if the colors and offsets were constant, wouldn’t a multi-line (commands MLSTYLE and MLINE) suit better?
Maybe you're right MSasu, Guess satishrajdev and myself both jump the gun then! spank.gif
:rofl:
Just throwing it out there pick only the obj but you know then which side is the offset side without a extra pick point for direction, yes it can be done. An intelligent offset routine. Sorry to hijack post.
....Sorry to hijack post....
No worries Bigal,the way i see it, it was us who hijack the post :lol:
