Hello,
I have faced following issue:
I tried to use AutoCAD 2013 accoreconsole.exe to batch plot drawings with following .bat -file.
cd "C:\Program Files\Autodesk\AutoCAD 2013"
c:
cls
accoreconsole.exe /i "C:\ä\drawing1.dwg" /s "C:\LISP\plot.scr" /l en-US
Since I live in Scandinavia it's common to have scandinavian alphabets in folder names (would be a good policy not to use them).
The accoreconsole.exe transforms scandinavian alphabets to weird symbols and throws error "file not found". Bat -file works fine for files with path that doesn't include scandinavian alphabets.
How come acad.exe is able to open files with scandinavian alphabet? Aren't these using the same language packs? There is no scandinavian language pack for AutoCAD (I have found none).
Is there a way to create custom language packs or some other workaround?
Thanks in advance.
I think that this is related to the BAT file, not to AutoCAD. Please check if this solution is useful for you.
MSasu
Yes, this was the problem:
I changed file character set to 865 (easy in Notepad++) and it started to work.
Thanks!
Glad to hear this is solved. You're welcome!
