Z value referencing block
Hi,
Does anybody know a way of creating a block attribute that will reference the z value of a separate 3d model (topographical survey) at a given point?
I know the z value of the block itself can be listed as a simple block attribute but I need the reference to check for the z value of an unlinked model which will be inserted/ x-reffed beneath the block.
Any ideas?
Thanks
Al
Create a block that consists only of a point, with an attribute that shows the Z value of the point.
The block inserted in a drawing, even if the input point is selected on an X-ref will show the height !
Hi Steven,
The block would need to have multiple points (corners of a building) and would not necessarily snap directly onto an object on the topo. To be honest I'm not sure it's something that's really possible having though about it.
Regards
Al
 Share
