Good Morning,
I again need some assistance with a lisp program to convert Celsius to Fahrenheit and vise versa, these will need to be in two separate programs in a single file. Here are my input and outputs needed:
Input: Enter temperature in Celsius : x
Ouput: x.x degrees Celsius is equivalent to xx.x degrees Farhrenheit.
the second program will simply be flipped:
Input: Enter temperature in Fahrenheit: x
Output: xx.x degrees Fahrenheit equivalent to x.x degrees Celsius.
The algorithms needed are: C= 5/9 (F-32)
F= (9/5 ©) +32
Here is what I have thus far for setting Celsius to C and the formula for Celsius to F is represented by C2F:
(defun C:CONV-TEMP ( / )
;; Celsius to Fahrenheit
(setq C (getreal "\nEnter
temperature in Celsius: ")
(setq C2F (+ (* (/ 9 5) C) 32)
(textscr)
(prompt (strcat (rtos F 2 1) "\ndegrees Celsius is equivalent to"
(rtos C2F 2 1) "degrees Fahrenheit."))
;;Fahrenheit to Celsius
(setq F (getreal "\nEnter
temperature in Fahrenheit: ")
(setq F2C (* (- F 32) (/ 5 9))
(textscr)
(prompt (strcat (rtos C 2 1) "\ndegrees Fahrenheit
equivalent to" (rtos F2C 2 1) "degrees Celsius."))
);eop
Thank you for any help/direction.
Acadstudent
Edited by CADTutor
Original post restored
Please look for INITGET and GETKWORD functions.
Also, for user input, is a good programming practice to validate it:
(if ([i]getsomething[/i])
 ;your processing
I'm receiving malformed list on input, but prior to debugging, is this what you're suggesting?
(initget 1 "Yes No")
(if (="Yes" (getkword "\nConvert
Celsius to Fahrenheit? [Yes/No]: " ))
(setq C (getint (+ 1 2 "\nEnter temperature in Celsius:
(textscr)
); Close first if statement
(if (="No")
(setq F (getreal "\nEnter temperature in Fahrenheit: ")
(textscr)
);close second if statement
);eop
Edited by CADTutor
That means that you have some un-balanced pharenthesis - please pay more attention to code formatting to be able to notice those issues by yourself.
I have fixed your code; please compare it with yours to understand my changes (since I didn't commented them all).
(defun C:CONV-TEMP( / [color=red]C C2F F F2C[/color] )   [color=red];localize variables[/color]
(if (= "Yes" (getkword "\nConvert Celsius to Fahrenheit? [Yes/No]: " ))
 [color=red](progn [/color]
  (setq C (getint "\nEnter temperature in Celsius: "))   [color=red];why constrain to integer?!?[/color]
  (setq C2F (+ (* (/ 9[color=red].0[/color] 5[color=red].0[/color]) C) 32))                    [color=red];ALWAYS use real values for division[/color]
  (textscr)
  (prompt (strcat [color=red]"\n"[/color] (rtos C 2 1) " degrees Celsius is equivalent to " (rtos C2F 2 1) " degrees Fahrenheit."))   [color=red];spaces!!![/color]
 [color=red])[/color]; Close if branch
 [color=red](progn[/color]
;;  Fahrenheit to Celsius
  (setq F (getreal "\nEnter temperature in Fahrenheit: "))
  (setq F2C (* (- F 32) (/ 5[color=red].0[/color] 9[color=red].0[/color])))                    [color=red];ALWAYS use real values for division[/color]
  (textscr)
  (prompt (strcat [color=red]"\n"[/color] (rtos F 2 1) " degrees Fahrenheit equivalent to " (rtos F2C 2 1) " degrees Celsius."))   ;spaces!!!
 [color=red])[/color]; Close else branch
);eop
Dear acadstudent,
Dont reedit you post after getting solution for your problem, may other people are after the same issue...
Acadstudent, please don't do this anymore! There may be others that will learn from this (complete) discussion. Or even you may be the one to benefit by getting better advice when the thread comes to attention of more experienced programmers.
aaaaaaaaaaaaaaaaaaaaaaaaaa
What in the world is this? :unsure:
There were two code excerpts that got removed meantime.
Oops, sorry about that. i did not read thru the whole thread, I was starting to think you're a mind reader MSasu the way you replied with just a "shout" from the OP :rofl:
I've restored the original posts so that this thread makes sense again.
Well-done..... But OP should aware of such thing to not to do....:thumbsup:
