dusko Posted November 28, 2008 Posted November 28, 2008 hello! i have some old drawings and this warning occur: 8 errors were found during opening. we recommend that you cancel this open and run RECOVER on the drawing. ok, i've done RECOVER and then he said: audit detected no errors in recovered database. if i look in ac text window there is information that said: Reading handle 4749 object type AmdtNoteTemplateDB Error 34 (eWrongObjectType) Object discarded what is meaning of this!? thank you! Quote
ReMark Posted November 28, 2008 Posted November 28, 2008 Do you know what software was used to create the drawings? Quote
dusko Posted November 28, 2008 Author Posted November 28, 2008 i think it is ac 2004. is it possible that problem is in code for letter phi. because i find code that is look like this: {\fSymbol|b0|i0|c2|p18;f} and not like this: %%c = phi Quote
ReMark Posted November 28, 2008 Posted November 28, 2008 I am not familiar with the posted error message. You might try a search of the AutoDesk Discussion Group for AutoCAD 2004 or a search of the AUGI Discussion forums. Sorry. Can you open the drawing and work with it at this point in time? Did you try purging the drawing? Quote
dusko Posted November 29, 2008 Author Posted November 29, 2008 after RECOVER file is opened but i wasn't sure if everything is ok. i PURGEd the drawing, replace the code for phi and after that everything is ok. Quote
