Lee Mac Posted September 4, 2015 Posted September 4, 2015 car = beginning of list (what list?) cdr = end of list (what list?) "(what list?)" The list of point coordinate values. Consider that your variable 'a' (whether obtained using getpoint or otherwise) holds a 2D or 3D list of point values: (<X-value> <Y-value> [Z-value]) For example, something like: (1.23 2.45 3.56) Now observe the following console demonstration: _$ (setq a '(1.23 2.45 3.56)) (1.23 2.45 3.56) _$ (car a) 1.23 _$ (cdr a) (2.45 3.56) _$ (1- (car a)) 0.23 _$ (cons (1- (car a)) (cdr a)) (0.23 2.45 3.56) As for mapcar, forget it It's not as complicated as it may first appear, the expression: (mapcar '- a '(1 0 0)) Is equivalent to: (list (- (car a) 1) (- (cadr a) 0) (- (caddr a) 0)) So, using the above example for the point 'a': _$ (setq a '(1.23 2.45 3.56)) (1.23 2.45 3.56) Then the mapcar expression: _$ (mapcar '- a '(1 0 0)) (0.23 2.45 3.56) Is the same as: _$ (list (- 1.23 1) (- 2.45 0) (- 3.56 0)) (0.23 2.45 3.56) You may find my mapcar tutorial helpful in this respect. Quote
Happy Hobbit Posted September 4, 2015 Posted September 4, 2015 (edited) I can see that mapcar could be very useful in manipulating lists I wonder if it might help defining 3 entmake expressions At the moment to define rectangles I have: (if (< w 15) (progn ; 'then' make mtext at ends ;;;------------------- mtext on LH side ---------------------;;; (entmake ;; Append the following DXF data to the drawing database (list ;; Construct a list containing the following DXF data '(000 . "MTEXT") ;; Entity type '(100 . "AcDbEntity") ;; Subclass marker '(100 . "AcDbMText") ;; Subclass marker (cons 10 (polar a pi 1)) ;; Insertion point '(001 . "Bacon \n& Eggs") ;; Content '(040 . 1.5) ;; Height (cons 050 ang) ;; Rotation in radians '(071 . 6) ;; Justification: 2 = Top Centre, 4 = Middle Left, 6 = Middle Right ) ;; end list ) ;; end entmake (princ) ;; Suppress the output of the value returned by the last evaluated expression ;;;------------------- mtext on RH side ---------------------;;; (entmake ;; Append the following DXF data to the drawing database (list ;; Construct a list containing the following DXF data '(000 . "MTEXT") ;; Entity type '(100 . "AcDbEntity") ;; Subclass marker '(100 . "AcDbMText") ;; Subclass marker (cons 10 (polar b 0 1)) ;; Insertion point '(001 . "Bacon \n& Eggs") ;; Content (cons 050 ang) ;; Rotation in radians '(040 . 1.5) ;; Height '(071 . 4) ;; Justification 2 = Top Centre, Justification 4 = Middle Left, Justification 6 = Middle Right ) ;; end list ) ;; end entmake (princ) ;; Suppress the output of the value returned by the last evaluated expression );; End progn ;;;------------------- mtext on RH side of 'a' rotated 90 degrees ---------------------;;; (progn (entmake ;; Append the following DXF data to the drawing database (list ;; Construct a list containing the following DXF data '(000 . "MTEXT") ;; Entity type '(100 . "AcDbEntity") ;; Subclass marker '(100 . "AcDbMText") ;; Subclass marker (cons 10 (polar a ang 1.5)) ;; Insertion point '(001 . "Bacon & Eggs") ;; Content [single line] '(040 . 2.0) ;; Height (cons 050 per) ;; Rotation in radians '(071 . 2) ;; Justification 2 = Top Centre, Justification 4 = Middle Left, Justification 6 = Middle Right ) ;; end list ) ;; end entmake ); end progn ); end (if (< w 15) Could the 3 'entmake' expressions be condensed into one bearing in mind the 3 different text justifications, 2 line text twice & two different text heights? Sorry to be a pain Harry Edited October 17, 2015 by Happy Hobbit Quote
Happy Hobbit Posted September 9, 2015 Posted September 9, 2015 Further to the above, I'm trying to sort a if or and statement. It's to keep the mtext readable no matter what angle the main entity is drawn at. The code I'm using: (defun c:Slotmtx (/ a a1 a2 ang b b1 b2 dist dist2 hght ins obm r ssize trot w) (setvar "plinewid" 0) (command "ORTHO" "OFF") (command "SNAP" "ON") (setq obm (getvar "blipmode")) (initget 7) (setvar "blipmode" 1) (initget 1) (setq a (getpoint "\nLocate first center: ")) (initget 1) (setq b (getpoint a "\nLocate second center: ")) (setvar "blipmode" 0) (setq ang (angle a b)) (initget "10 20 30 40 50 60 Custom") (setq ssize (cond ((getkword "\nWidth of slot? [10/20/30/40/50/60/Custom] <10>: ")) ("10"))) (cond ((eq ssize "10") (setq w 10) ) ((eq ssize "20") (setq w 20) ) ((eq ssize "30") (setq w 30) ) ((eq ssize "40") (setq w 40) ) ((eq ssize "50") (setq w 50) ) ((eq ssize "60") (setq w 60) ) ((eq ssize "Custom") (setq w (getreal "\nCustom Slot Size?")) ) );end cond (setq r (/ w 2)) (setq a1 (polar a (- ang (/ pi 2)) r) a2 (polar a (+ ang (/ pi 2)) r) b1 (polar b (- ang (/ pi 2)) r) b2 (polar b (+ ang (/ pi 2)) r) dist (distance a b) dist2 (/ dist 2) ins (polar a ang dist2) hght (/ w 4) );end setq (setvar "cmdecho" 0) (command ".pline" a1 b1 "A" b2 "L" a2 "A" "CL") ;;;------------------- Start insert mtext function ---------------------;;; (if(or (<= ang (* pi 0.5)) (> ang (* pi 1.5))) (setq trot ang) (setq trot (+ ang pi )) );end if (command "-layer" "M" "TEXT" "C" "3" "" "");; sets layer to TEXT or creates layer TEXT if it doesn't exist ;;;------------------- MC mtext in centre of box ---------------------;;; (entmake ;; Append the following DXF data to the drawing database (list ;; Construct a list containing the following DXF data '(000 . "MTEXT") ;; Entity type '(100 . "AcDbEntity") ;; Subclass marker '(100 . "AcDbMText") ;; Subclass marker (cons 10 ins) ;; Insertion point '(001 . "SLOT\n No. ") ;; Content (cons 040 hght) ;; Height (cons 050 trot) ;; Rotation in radians '(071 . 5) ;; Justification: 2 = TC, 4 = ML, 5 = MC, 6 = MR ) ;; end list ) ;; end entmake ;;;------------------- End insert mtext function ---------------------;;; (setvar "cmdecho" 1) (setvar "blipmode" obm) (command ".BLIPMODE" "off") (princ) ) I'm not sure the code is right, although the following seems to work ok: (if(or (<= ang (* pi 0.5)) (> ang (* pi 1.5))) My code is missing the 'less than 180°' bit Please can anyone help me construct an 'if and or' to suit? Quote
