Revit 2014 Vanilla - How to create a Concrete pile
Hey,
Just got Revit 2014 and having a play round with it to see what's been added, where's stuff has been moved to etc. etc.
Right now, I'm looking at how to create a 600dia. pile. Is this possible through using Structural --> Column, and Edit Type? As I don't see a way to.
The only column I can produce right now is a 305x305x97UC. While I know how to create other steel columns, I'm hoping to create a concrete pile that I can then place within a small concrete slab.
Any feedback is greatly appreciated.
I say Vanilla Revit 2014 as there's no addons applied to it, and not the nice food that I like to consume. :popcorn:
Make sure you load in a Concrete Column Family. You can make the diameter any size you want, but you gotta load in the content first. :)
Thanks frampton. How do I load in these families? Where can I find them? :)
Edited by PotGuy
Application Start > Options > File Locations > Places Button. Or, when you go to the Ribbon Insert Tab> Load Family, it should be defaulted. If not, look to the Folders on the left - it should be an option for your Metric Library.
Just FYI: Everything in Revit is a Family. I'd suggest you memorize this Content Library location, because without it, Revit is a really expensive program that can't do much.
