Problem with SAT file
Hi All,
Normally when I open other SAT files, I receive it in Inventor as an assembly file.
But on this file I get it in ipt format.
How can I convert it to assembly file?
When opening the file select the filename, but before opening click on Options to see what options have been set.
or
go to Manage tab>Make Components and this will push out the parts (you select) and create the assembly. (keep the original with the new files - do not delete it)
Thanks mate.
I have played with your first option previously but couldn't make it, however your second option was really cool.
