project toward a line in a perpendicular angle
Hi
my problem is like this :
in some points in my script the lisp generate a line, than i ask the user to set a point in a specific location , the point than has to project toward the line in a perpendicular angle , and than perform break on the intersected point.
i have no clue how to do it or if its even possible
see attchment
Thanks in advance
Shay
Please check the vlax-curve-getClosestPointTo function; the shortest distance from a point to a line is its projection on said line (the perpendicular).
(defun c:demo ()
 (command "_.line" "\\" "\\" "")
 (setq lin (entlast))
 (command "_point" "\\")
 (setq p (vlax-curve-getClosestPointTo lin (getvar 'lastpoint)))
 (command "_break"
   lin
   "_non"
   "_non"
   p
EDIT: Oops. Msasu beat me to it anyhoo try the demo code :)
thank you
what is "\\" ? (cant excute right now)
i think there is aproblem with `lastpoint
im using cad 2010
its "lastpoint" that works
Thanks again
Shay
thank you
Replace it with pause and try again .
i see
thanx
