Hi guys! :D
I'm using that excellent code from Mr. Lee Mac.
And I need a help to make a little modification in that code.
I'd like to control the text size. That code doesn't have any option for that.
Anybody Can help me out, please?
Thank in advance
;;-------------------=={ Areas 2 Field }==--------------------;;
;;  Creates an MText object containing a Field Expression     ;;
;;  referencing the area, or sum of areas, of one or more     ;;
;;  selected objects.                                         ;;
;;  Author: Lee Mac, Copyright © 2013 - www.lee-mac.com       ;;
;;  Version 1.2    -    26-05-2013                            ;;
(defun c:a2f ( / *error* fmt inc ins lst sel str )
   (setq fmt "%lu6%qf1%ds44%th46") ;; Field Formatting
   (defun *error* ( msg )
       (LM:endundo (LM:acdoc))
       (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
   (if
       (and
           (setq sel (ssget '((0 . "ARC,CIRCLE,ELLIPSE,HATCH,*POLYLINE,REGION,SPLINE"))))
           (setq ins (getpoint "\nPick Point for Field: "))
           (if (= 1 (sslength sel))
               (setq str
                   (strcat
                       "%<\\AcObjProp Object(%<\\_ObjId "
                       (LM:ObjectID (vlax-ename->vla-object (ssname sel 0)))
                       ">%).Area \\f \"" fmt "\">%"
                   (repeat (setq inc (sslength sel))
                       (setq lst
                           (vl-list*
                               (LM:ObjectID (vlax-ename->vla-object (ssname sel (setq inc (1- inc)))))
                               ">%).Area>%" " + "
                               lst
                   (setq str
                       (strcat
                           "%<\\AcExpr "
                           (apply 'strcat (reverse (cdr (reverse lst))))
                           " \\f \"" fmt "\">%"
           (LM:startundo (LM:acdoc))
           (vla-addmtext
               (vlax-get-property (LM:acdoc) (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace))
               (vlax-3D-point (trans ins 1 0))
               0.0
               str
;; ObjectID  -  Lee Mac
;; Returns a string containing the ObjectID of a supplied VLA-Object
;; Compatible with 32-bit & 64-bit systems
(defun LM:ObjectID ( obj )
   (eval
       (list 'defun 'LM:ObjectID '( obj )
           (if
               (and
                   (vl-string-search "64" (getenv "PROCESSOR_ARCHITECTURE"))
                   (vlax-method-applicable-p (vla-get-utility (LM:acdoc)) 'getobjectidstring)
               (list 'vla-getobjectidstring (vla-get-utility (LM:acdoc)) 'obj ':vlax-false)
              '(itoa (vla-get-objectid obj))
   (LM:ObjectID obj)
;; Start Undo  -  Lee Mac
;; Opens an Undo Group.
(defun LM:startundo ( doc )
   (LM:endundo doc)
   (vla-startundomark doc)
;; End Undo  -  Lee Mac
;; Closes an Undo Group.
(defun LM:endundo ( doc )
   (while (= 8 (logand 8 (getvar 'undoctl)))
       (vla-endundomark doc)
;; Active Document  -  Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
   (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
   (LM:acdoc)
(vl-load-com) (princ)
;;                        End of File                         ;;
Hi
Read Lee's instruction page for this LISP.
Also
If I recall the th refers to text height. I'm sure Lee will confirm.
Hi Spaj,
Thanks for the quick replay
I was thinking if possible to create a input for the text size instead of modify inside the code.
Hi Madruga,
Since the program is creating an MText Field, the text height will be determined by the value of the TEXTSIZE system variable at the time of running the program.
However, here is a quick mod to include an additional prompt for the height:
;; Modified to prompt for text height  -  Lee Mac 2013-12-18
(defun c:a2f ( / *error* fmt hgt inc ins lst sel str )
   ;; <Modified>
   (initget 6)
   (if (setq hgt (getdist (strcat "\nSpecify text height <" (rtos (getvar 'textsize)) ">: ")))
       (setvar 'textsize hgt)
       (setq hgt (getvar 'textsize))
   ;; </Modified>
   (if
       (and
               (setq str
                   (strcat
                       (setq lst
                           (vl-list*
                               ">%).Area>%" " + "
                               lst
                   (setq str
                       (strcat
                           "%<\\AcExpr "
           (vla-put-height ;; mod
               (vla-addmtext
                   0.0
                   str
               hgt ;; mod
           ) ;; mod
   (eval
           (if
               (and
   (LM:ObjectID obj)
   (LM:endundo doc)
(defun LM:acdoc nil
   (LM:acdoc)
@Spaj, thank you for your responses + suggestions, appreciated.
Wow!
many Thanks Mr. Lee,
The modification improved the code. Make it better!
Regards
:notworthy:
  • 3 weeks later...
Hi guys,
How Can I put the text area only 2 decimal units?
I'd like to learn which part of the code I can do that.
Anybody Can teach me, please?
Best Regards
Hi guys,
Best Regards
Change the LUPREC system variable to your desired one ;)
Thank for the quick replay Tharwat,
I'd like to put it inside the code. I mean always been 2 decimal units
Because I know how change it through LUPREC, but today I forgot to change it and I plot the wrong text.
No worries :D
Add the following line at the top of the routine and you'd get it equal to two all the time .
(setvar 'LUPREC 2)
I've already calculate all areas in my project with 2 decimal units.
But today when I opened the project, I didn't realize that LUPREC was 3 and plot the wrong area.
I was wondering if there is any way to lock the area showing always 2 decimal units.
Thank in advance
