pdf in large format?
hey everybody,
is there a way to pdf a large format drawing?
i can only find A4 size..
thanks
yes there is but it will depend on what pdf printer you are using...you may be able to create a custom paper size via the printer's properties but again it will depend on the pdf printer...our office uses PDFcreator and i personally use acrobat pro of which either can go as big as an A0 sheet...
It all depends on which pdf printer you use.
I use bullzip pdf. Its free to download.
It does upto A0+
Better than most of the ones out there.
I think that at least the later versions of AutoCAD have a PDF printer available which will print almost any size. CutePDF is nice but once I found the built-in I didn't need any outside drivers.
CAD 2006 doesnt have a pdf writer incorporated with the program.
I think it was only in cad2009 that they included it. I run cad2008 and have a pdf writer, but im not sure if the adobe pdf was included with cad2008
