tazzzz Posted December 19, 2013 Posted December 19, 2013 Hello, I have this excel macro that extracts blocks with attributes from an open acad dwg into an excel spreadsheet. I need your help to modify this code to be able to do this: -specify in the line code the name of the blocks I want to extract -specify in what columns each block will be extracted. I use AutoCAD 2011 and excel 2010 Bellow is the excel VBA code. Thank you for your help. Public acad As Object Public mspace As Object Public excel As Object Public AcadRunning As Integer Public excelSheet As Object Sub Extract() Dim sheet As Object Dim shapes As Object Dim elem As Object Dim excel As Object Dim Max As Integer Dim Min As Integer Dim NoOfIndices As Integer Dim excelSheet As Object Dim RowNum As Integer Dim Array1 As Variant Dim Count As Integer Set excel = GetObject(, "Excel.Application") Set excelSheet = excel.ActiveWorkbook.ActiveSheet excelSheet.Range(Cells(1, 1), Cells(45, ).Clear excelSheet.Range(Cells(1, 1), Cells(1, ).Font.Bold = True excelSheet.Range(Cells(1, 1), Cells(1, ).Font.Color = 1152 Set acad = Nothing On Error Resume Next Set acad = GetObject(, "AutoCAD.Application") If Err <> 0 Then Set acad = CreateObject("AutoCAD.Application") acad.Visible = True MsgBox "Please open a drawing file and then restart this macro." Exit Sub End If Set doc = acad.ActiveDocument Set mspace = doc.ModelSpace RowNum = 1 Dim Header As Boolean Header = False For Each elem In mspace With elem If StrComp(.EntityName, "AcDbBlockReference", 1) = 0 Then If .HasAttributes Then Array1 = .GetAttributes For Count = LBound(Array1) To UBound(Array1) If Header = False Then If StrComp(Array1(Count).EntityName, "AcDbAttribute", 1) = 0 Then excelSheet.Cells(RowNum, Count + 1).Value = Array1(Count).TagString End If End If Next Count RowNum = RowNum + 1 For Count = LBound(Array1) To UBound(Array1) excelSheet.Cells(RowNum, Count + 1).Value = Array1(Count).TextString Next Count Header = True End If End If End With Next elem NumberOfAttributes = RowNum - 1 If NumberOfAttributes > 0 Then ActiveWorkbook.ActiveSheet.Range("A1").Sort _ key1:=ActiveWorkbook.ActiveSheet.Columns("A"), _ Header:=xlGuess Else MsgBox "No attributes found in the current drawing." End If Set acad = Nothing End Sub Private Sub Auto_Close() Set excelSheet = Nothing End Sub Quote
BIGAL Posted December 19, 2013 Posted December 19, 2013 You need to dig a bit deeper here (.EntityName, "AcDbBlockReference", 1) this returns yes its a block, then you would add another if, is it = to my blockname in a looping list for desired blocks. maybe selection set generated directly as a group of 1 block objects. FilterDXFCode(0) = 0 FilterDXFVal(0) = "INSERT" FilterDXFCode(1) = 2 FilterDXFVal(1) = "DA1DRTXT" BLOCK_NAME = "DA1DRTXT" Set SS = ThisDrawing.SelectionSets.Add("issued") SS.Select acSelectionSetAll, , , FilterDXFCode, FilterDXFVal For Cntr = 0 To SS.Count - 1 attribs = SS.Item(Cntr).GetAttributes attribval1 = attribs(1).TextString Quote
RICVBA Posted December 20, 2013 Posted December 20, 2013 Hello,I have this excel macro that extracts blocks with attributes from an open acad dwg into an excel spreadsheet. I need your help to modify this code to be able to do this: -specify in the line code the name of the blocks I want to extract -specify in what columns each block will be extracted. I use AutoCAD 2011 and excel 2010 Bellow is the excel VBA code. Thank you for your help. Public acad As Object Public mspace As Object Public excel As Object Public AcadRunning As Integer Public excelSheet As Object Sub Extract() Dim sheet As Object Dim shapes As Object Dim elem As Object Dim excel As Object Dim Max As Integer Dim Min As Integer Dim NoOfIndices As Integer Dim excelSheet As Object Dim RowNum As Integer Dim Array1 As Variant Dim Count As Integer Set excel = GetObject(, "Excel.Application") Set excelSheet = excel.ActiveWorkbook.ActiveSheet excelSheet.Range(Cells(1, 1), Cells(45, ).Clear excelSheet.Range(Cells(1, 1), Cells(1, ).Font.Bold = True excelSheet.Range(Cells(1, 1), Cells(1, ).Font.Color = 1152 Set acad = Nothing On Error Resume Next Set acad = GetObject(, "AutoCAD.Application") If Err <> 0 Then Set acad = CreateObject("AutoCAD.Application") acad.Visible = True MsgBox "Please open a drawing file and then restart this macro." Exit Sub End If Set doc = acad.ActiveDocument Set mspace = doc.ModelSpace RowNum = 1 Dim Header As Boolean Header = False For Each elem In mspace With elem If StrComp(.EntityName, "AcDbBlockReference", 1) = 0 Then If .HasAttributes Then Array1 = .GetAttributes For Count = LBound(Array1) To UBound(Array1) If Header = False Then If StrComp(Array1(Count).EntityName, "AcDbAttribute", 1) = 0 Then excelSheet.Cells(RowNum, Count + 1).Value = Array1(Count).TagString End If End If Next Count RowNum = RowNum + 1 For Count = LBound(Array1) To UBound(Array1) excelSheet.Cells(RowNum, Count + 1).Value = Array1(Count).TextString Next Count Header = True End If End If End With Next elem NumberOfAttributes = RowNum - 1 If NumberOfAttributes > 0 Then ActiveWorkbook.ActiveSheet.Range("A1").Sort _ key1:=ActiveWorkbook.ActiveSheet.Columns("A"), _ Header:=xlGuess Else MsgBox "No attributes found in the current drawing." End If Set acad = Nothing End Sub Private Sub Auto_Close() Set excelSheet = Nothing End Sub as for the excel coding, it actually seems fit to list a single blockname occurrence but you'd better post an example of what are you actual needs in terms of blocks listing. if I get it well, you'd like to list all references of every different block names in different columns groups. if so, every list structure is strictly connected to the number of tags of every block, which most probably differ from one another. so it could be more effective to set and use a different sheet for every block to be processed. let me know. in the meanwhile I think you should do at least the following changes 1) Set excelSheet = Excel.ActiveWorkbook.ActiveSheet With excelSheet .Range(.Cells(1, 1), .Cells(45, ).Clear .Range(.Cells(1, 1), .Cells(1, ).Font.Bold = True .Range(.Cells(1, 1), .Cells(1, ).Font.color = 1152 End With to make the code run 2) For Count = LBound(Array1) To UBound(Array1) excelSheet.Cells(RowNum, Count + 1).Value = Array1(Count).TextString Next Count and 3) If NumberOfAttributes > 0 Then excelSheet.Range("A1").Sort _ key1:=excelSheet.Columns("A"), _ Header:=xlGuess Else both only to have a consequent usage of variables you correctly set at the beginning 4) If .HasAttributes Then Array1 = .GetAttributes If Header = False Then For Count = LBound(Array1) To UBound(Array1) If StrComp(Array1(Count).EntityName, "AcDbAttribute", 1) = 0 Then excelSheet.Cells(RowNum, Count + 1).Value = Array1(Count).TagString End If Next Count Header = True End If RowNum = RowNum + 1 For Count = LBound(Array1) To UBound(Array1) excelSheet.Cells(RowNum, Count + 1).Value = Array1(Count).TextString Next Count End If to avoid unuseful checkings once you process the tagstring. of course all what above is to be rewritten to match both Bigal suggestion and, if the case, the one-sheet-for-every-blockname setup Quote
tazzzz Posted December 20, 2013 Author Posted December 20, 2013 Thank you so much for your reply. I have applied your suggestions into the code, and I feel it is running smoother than before , but still I don’t have the ability to manipulate data. I followed your suggestion and I created a small EXCEL example of data: 1. data extraction will start with column BA 2. Col BA & BB correspond to attributes from Block1 3. Col BC & BD correspond to attributes from Block2 4. Col Be corresponds to attributes from Block3 and … so on. Is there a way to declare what blocks/attributes to be extracted and where? Thank you for your help and time you put in. EXCEL block listing.xlsx Quote
RICVBA Posted December 22, 2013 Posted December 22, 2013 Thank you so much for your reply. I have applied your suggestions into the code, and I feel it is running smoother than before , but still I don’t have the ability to manipulate data. I followed your suggestion and I created a small EXCEL example of data: 1. data extraction will start with column BA 2. Col BA & BB correspond to attributes from Block1 3. Col BC & BD correspond to attributes from Block2 4. Col Be corresponds to attributes from Block3 and … so on. Is there a way to declare what blocks/attributes to be extracted and where? Thank you for your help and time you put in. Sure there is! Tomorrow I'll spend some time and let you have a code that will allow you to "dig deeper" and reach your goal. Quote
RICVBA Posted December 23, 2013 Posted December 23, 2013 Sure there is! Tomorrow I'll spend some time and let you have a code that will allow you to "dig deeper" and reach your goal. this the vba listing Option Explicit Sub Extract() If ThisDrawing Is Nothing Then MsgBox "Please open a drawing file and then restart this macro." Exit Sub End If '------------------------------------------------------- 'Excel setup Dim Excel As Application Dim MySheet As Excel.Worksheet Dim BlckNameRng As Excel.Range, TagsRng As Excel.Range, myCell As Excel.Range Dim iniColStr As String Dim iniRow As Long, iniCol As Long ' handling excel application On Error Resume Next Set Excel = GetObject(, "Excel.Application") If Err Then Set Excel = CreateObject("Excel.Application") ' handling workbook and worksheet With Excel .Visible = True Set MySheet = .ActiveWorkbook.ActiveSheet If Err Then .Workbooks.Add .ActiveWorkbook.Worksheets.Add Set MySheet = .ActiveWorkbook.ActiveSheet End If On Error GoTo 0 End With 'handling columns where to start writing data from iniColStr = "BA" '<-- Here you specify which column to start writing data from iniRow = 2 '<-- Here you specify which row to start writing data from iniCol = MySheet.Range(iniColStr & "1").Column Set BlckNameRng = MySheet.Cells(iniRow, iniCol).Resize(, 1000) ' this will clear excel cells in 1000 columns right of the initial one Set TagsRng = BlckNameRng.Offset(1) With BlckNameRng .EntireColumn.Clear With .Font .Bold = True .color = 1152 End With End With '------------------------------------------------------- '------------------------------------------------------- 'blocks reference searching&handling Dim myBlckRef As AcadBlockReference Dim Attrs As Variant Dim nBlckRefs As Integer, iBlckRef As Integer, nAttrs As Integer, iAttr As Integer, nTags As Integer Dim BlckName As String, BlckHandle As String Dim gpCode(0) As Integer Dim dataValue(0) As Variant Dim ssetObj As AcadSelectionSet Dim myRow As Long, myCol As Long Dim LBnd As Integer, Ubnd As Integer 'selecting block references in the active drawing gpCode(0) = 0 dataValue(0) = "INSERT" On Error Resume Next Set ssetObj = ThisDrawing.SelectionSets.Add("BlockRefSset") If Err <> 0 Then Set ssetObj = ThisDrawing.SelectionSets.Item("BlockRefSset") Else ssetObj.Clear End If On Error GoTo 0 ssetObj.Select acSelectionSetAll, , , gpCode, dataValue 'handling block references found nTags = 0 ' this counter will keep track of the number of columns filled with blockreferences data ("handles" and "attributes") nBlckRefs = ssetObj.Count For iBlckRef = 0 To nBlckRefs - 1 Set myBlckRef = ssetObj.Item(iBlckRef) If myBlckRef.HasAttributes Then ' getting blockreference info With myBlckRef BlckName = .Name BlckHandle = .Handle Attrs = .GetAttributes End With LBnd = LBound(Attrs) Ubnd = UBound(Attrs) nAttrs = Ubnd - LBnd + 1 ' handling excel list structure consequent to blockreference blockname Set myCell = BlckNameRng.Find(BlckName, lookin:=xlValues) ' searching for blockname existence If myCell Is Nothing Then 'if the blockname hasn't already been met-> registered 'then we have to arrange new columns to house blockreference data (handle and attributes tagstrings and textstrings) myCol = nTags + 1 ' setting ref column (where to start writing from) one to the right of the last one nTags = nTags + 1 + nAttrs ' update number of columns to be filled with data: the "1" is for the "handle" column ' writing block header cells With BlckNameRng(1, myCol) .Value = BlckName With .Resize(, nAttrs + 1) .Merge .BorderAround (xlContinuous) .HorizontalAlignment = xlCenter End With End With ' writing blockreference data header cells (handle and attributes tags) With TagsRng(1, myCol) .Value = "HANDLE" .BorderAround (xlContinuous) 'every block data heade is boxed For iAttr = LBnd To Ubnd With .Offset(0, 1 + iAttr - LBnd) .Value = Attrs(iAttr).TagString .BorderAround (xlContinuous) .HorizontalAlignment = xlCenter End With Next iAttr End With Else ' if the blockname has already been listed myCol = myCell.Column - BlckNameRng.Column + 1 'set ref column to the found cell one End If 'writing blockreference data cells With BlckNameRng.Offset(, myCol - 1).EntireColumn myRow = .Cells(.Rows.Count, 1).End(xlUp).Offset(1).Row ' getting the first free cell in the column With .Cells(myRow, 1) .Borders(xlEdgeLeft).LineStyle = xlContinuous ' left border the 1st column .Value = BlckHandle ' writing handle data For iAttr = LBnd To Ubnd .Offset(0, 1 + iAttr - LBnd).Value = Attrs(iAttr).TextString ' writing attributes string data Next iAttr .Offset(0, 1 + Ubnd - LBnd).Borders(xlEdgeRight).LineStyle = xlContinuous ' right border the last column End With End With End If Next iBlckRef '------------------------------------------------------- With BlckNameRng.CurrentRegion .Columns.AutoFit .Select End With Set Excel = Nothing End Sub it works with W7-32bit, Acad2010 and Excel 2010, establishing references to: - Visual Basic for Application - Autocad 2011 type library (!!) - Microsoft Excel 14.0 Object Library I wrote it from scratch, but you'll find commented codelines so as you can go on your way and make all changes you need. Quote
tazzzz Posted December 23, 2013 Author Posted December 23, 2013 Hello RICVBA I am really impressed with the amount of work you put into this code and honestly I am speechless. I embedded this code into my EXCEL spreadsheet but when I try to run the macro I have a message of error "variable not defined". Do you think windows 7-64 bit has something to do with this? Thank you Quote
RICVBA Posted December 23, 2013 Posted December 23, 2013 Hello RICVBAI am really impressed with the amount of work you put into this code and honestly I am speechless. I embedded this code into my EXCEL spreadsheet but when I try to run the macro I have a message of error "variable not defined". Do you think windows 7-64 bit has something to do with this? Thank you tazzzz, I wrote the vba code from Autocad "perspective". i.e.: you have to open VBA IDE in Autocad (not in Excel), insert a Module and paste the code into its code window, and debug it. don't forget to make sure you have set proper references. after that, 32-64 bit issues could apply. But I hope this will not happen, since I wouldn't be able to support you. Quote
tazzzz Posted December 23, 2013 Author Posted December 23, 2013 Thank you so much for your clarification. If there will be an issue with 64bit I will find a way to go around. Quote
