mostafa badran Posted December 20, 2013 Posted December 20, 2013 Hi all. when I click into the VP its make zoom extent can anybody explain to me what is the matter . see attached.VP problem.dwg Quote
ReMark Posted December 20, 2013 Posted December 20, 2013 Since both are the same why not just delete the problematic one and copy the good one? OK...try this. Change the UCSFOLLOW system variable to 0 inside the viewport. Now what happens? Is the scale of the viewport to the left the final (good) scale or will you be changing it? Once you have determined the correct scale do you make it your habit to lock the viewport scale at that point? Quote
mostafa badran Posted December 20, 2013 Author Posted December 20, 2013 Since both are the same why not just delete the problematic one and copy the good one? OK...try this. Change the UCSFOLLOW system variable to 0 inside the viewport. Now what happens? Is the scale of the viewport to the left the final (good) scale or will you be changing it? Once you have determined the correct scale do you make it your habit to lock the viewport scale at that point? day by day I am sure is the cadtutor is the best site. because its has master to solve problems like you. thank so much. Quote
ReMark Posted December 20, 2013 Posted December 20, 2013 You are much too kind. But please note it is a group effort. I am just one amongst many and certainly not a master. You're entirely welcomed. Quote
