gort ben Posted December 22, 2013 Posted December 22, 2013 Can you round over existing solid forms in autocad 2010. My solid is 30mm thick and I want to round-over the edges with a 6.5mm radius. Quote
nestly Posted December 22, 2013 Posted December 22, 2013 Sure, use the FILLET command just as you would for filleting lines. Picking the edges is a bit different, see following video if needed. Quote
gort ben Posted December 22, 2013 Author Posted December 22, 2013 That worked brilliantly, thanks Quote
