How can I convert dxf to dwg in batch??
Hi Frinds,
I need to convert many dxf to dwg..
is it possible to do it at once..
Please help
Thanks in advance
Seems like a task best suited to batch processing via a script. Look at AutoDesk's own ScriptPro or forum member Lee Mac's program Script Writer.
  • 1 year later...
My solution. I made some change in Lee Mac's Script Writer (find "*.dwg" and replace "*.dxf") and add script line for dxf as default
Script Line
_.open *file* _.saveas 2007  _.close
!!!between 2007 and _.close is 2 spaces
2007 - required dwg file version (2004 2007 2010 2013)
DXFScriptWriterV1-2_VVA.lsp
Edited by VVA
  • 1 year later...
can you please explain how to use this lsp
The basic instructions on how to use ScriptWriter by Lee Mac can be found here....http://lee-mac.com/scriptwriter.html
A simple script
open dwg1.dxf saveas 2007 dwg1 close
open dwg2.dxf saveas 2007 dwg2 close
open dwg3.dxf saveas 2007 dwg3 close
