gemian01 Posted December 28, 2013 Share Posted December 28, 2013 hi, if anyone atall can help me out. I need to design an alloy wheel within autocad 2010 LT for next week, not in 3d, but with three views on a paper layout / plan layout, i am completely stumped and stuck. i found a dude making one in 3d, but as im using cad lt there is no 3d function. any help / advice would be much appreciated:lol: Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 28, 2013 Share Posted December 28, 2013 There is limited 3d capability in LT if you know how ok start set Thickness to 25mm draw a circle say 600mm dia and now type vpoint 1,1,1 you will have a vertical edge for a circle, copy last 0,0,0 0,0,125 you now have two egdes. Set thickness to 100 draw a circle say 575 dia. You get the idea from this no 3d solids then with a hide. Does LT support Revsurf ? If so then wheel rim can be made easy. Quote Link to comment Share on other sites More sharing options...
steven-g Posted December 28, 2013 Share Posted December 28, 2013 Nope no revsurf. The only limits in LT for 3D are the objects you can use (no solids - or surfaces) and the commands available, which make it difficult (it is possible, just not straightforward). I would suggest drawing the views separately (plan, front and side) but also draw the object in isometric. Do you have an example to work from. Quote Link to comment Share on other sites More sharing options...
