Mike55 Posted January 1, 2014 Posted January 1, 2014 I have 30 lisp routines I use all the time, so I made it all in to one big routine it run fine. Now I would like to change it from .lsp to .fas I use the vlide to change it, but 6 out of the 30 will not let me change to .fas all I get is this ; error: too many arguments: (WHILE (= PICK "3") (COMMAND ".insert" "ttv_3" "0,0" ... ) (COMMAND ".zoom" "0,0" "50,50") ... ); Compilation aborted: Fatal errors found. So then I tried to debug it in vlide all I get is Callback-entry? What can I do? Thanks Mike Quote
ymg3 Posted January 1, 2014 Posted January 1, 2014 Mike55, Post the offending routine. There must be something wrong in it. ymg Quote
Guest Posted January 4, 2014 Posted January 4, 2014 I use this lisp to convert a lisp to fas ;; LSP2FAS.lsp ; Scot Harris 11-29-2012 ;; Minimizes the sequence needed to create FAS files. ;; Help facility added. ;; Streamlined from original program provided by aqdam1978. (defun c:LSP2FAS-Help (/) (alert (strcat "\tLisp (LSP) to Fast and Secure (FAS) Help" "\n " "\nFile dialog begins in the current directory. " "\nIt is suggested to place and open a drawing (DWG) " "\ninside the input folder you wish to batch process. " "\n " "\nOutput file will be in the same folder as the file selected. " "\n " "\nThere is no provisional check for an existing FAS file of the same name. " )) );end LSP2FAS-Help (defun c:LSP2FAS ( / a ) (vl-load-com) (prompt " Lisp to Fast and Secure (FAS). LSP2FAS-Help available. ") (if (wcmatch (strcase (setq a (getfiled "Convert LSP File to FAS" (getvar "DWGPREFIX") "" 16))) "*.LSP") (progn (c:vlide)(vlisp-compile 'st a) (princ (strcat "\n File " (vl-string-subst ".fas" ".lsp" a) " created. ")) );progn (alert "File extension must be \".LSP\" ") );if (princ) );end LSP2FAS Quote
SLW210 Posted January 6, 2014 Posted January 6, 2014 Please read the Code posting guidelines and edit your post to include the Code in Code Tags. Quote
Mike55 Posted January 6, 2014 Author Posted January 6, 2014 (edited) When this comes up "\n Pick a number 1-35 and hit Enter ")) enter 3 When this comes up "\n Enter the T size 4-3/8 inches and up {A}: ")) enter 6 or > This is the offending routine. If you can get this to go into a .fas let me know how you got there step by step so I can fix the other 5? Thanks Mike Edited February 22, 2014 by Mike55 added [CODE] tags Quote
Mike55 Posted January 6, 2014 Author Posted January 6, 2014 (edited) I copied the text from my code and pasted it in, highlight the code and click the code button it still look the same? Type the code first? When this comes up "\n Pick a number 1-35 and hit Enter ")) enter 3 When this comes up "\n Enter the T size 4-3/8 inches and up {A}: ")) enter 6 or > This is the offending routine. If you can get this to go into a .fas let me know how you got there step by step so I can fix the other 5? Thanks Mike two day.dwg ttv_3.dwg Edited February 22, 2014 by Mike55 added [CODE] tags Quote
ymg3 Posted January 6, 2014 Posted January 6, 2014 Mike55, If you cannot abide by the posting guidelines and include Code tags, I don't see why we would spend time trying to help you. Look at what you posted with all those smileys!, we cannot use this crap. Maybe upload the lisp. ymg Quote
rkmcswain Posted January 6, 2014 Posted January 6, 2014 I copied the text from my code and pasted it in, I pasted your code into the VLIDE and ran "Tools>Check Text in Editor" and get this [CHECKING TEXT <Untitled-0> loading...] ..... ; error: too many arguments: (WHILE (= PICK "3") (COMMAND ".insert" "ttv_3" "0,0" ... ) (COMMAND ".zoom" "0,0" "50,50") ... ) ; Check done. If you move the closing parenthesis up a few lines, it checks out ok. I wonder if you have stumbled across some limitation to the number of arguments that (while) supports. It was discussed here many years ago, at least as it related to the length of lists. http://forums.autodesk.com/t5/AutoCAD-2000-2000i-2002-DWG/AutoLISP-List-Limits/td-p/229820 I just tried a simple function like this and it fails when the number of arguments get to 255. (while (= 3 3) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1) (setq a 1)) Quote
ymg3 Posted January 6, 2014 Posted January 6, 2014 Mike55, R.K. is right about the , error: too many arguments: If you replace those multiple setq in your code with the following syntax: (setq a "abc" b "def" c "ghi" etc.... ) Your while loop will now fit. I've done a few in the attachment and now the error disappear. 456.LSP Quote
ymg3 Posted January 7, 2014 Posted January 7, 2014 Mike55, By doing the setq like the above example the code see one argument regardless the number of setq That about sums it up! Glad we could help, but the merit is with R.K. McSwain ymg Quote
Mike55 Posted February 16, 2014 Author Posted February 16, 2014 Is there a size limit to lisp routines that can be change to .fas? I have two .lsp routines that are 31Kb and 28Kb, if I cut out any 50 line of code the routines will change to .fas if I leave in the 50 line of code I get (Too many argument). I tried to post just one of the .lsp routines but I'm over twice the limits for posting. Quote
MSasu Posted February 16, 2014 Posted February 16, 2014 That error sound like you call a function with more arguments that expected somewere in the removed 50 lines. What happen when you run the code un-compiled? It may help to post here only the said 50 lines. As per a limit, if there is one, it must be way-over 31Kb; I work with many LSP files in excess of 100Kb that were compiled without issues (even when more than one in a project; that it, complied to a single VLX). Quote
Mike55 Posted February 16, 2014 Author Posted February 16, 2014 (edited) I'm working on posting the code but it will not post? I'm starting a new post the code will not go in? Edited February 16, 2014 by Mike55 Quote
Mike55 Posted February 17, 2014 Author Posted February 17, 2014 when I post my code I get this The following errors occurred with your submission The text that you have entered is too long (27507 characters). Please shorten it to 15000 characters long. I copied my lisp highlighted it then hit the # and hit Post Quick Reply what am I do wrong? Quote
MSasu Posted February 17, 2014 Posted February 17, 2014 Since the issue seems to dissapear when you remove the said 50 lines, then it may help to post only them (I don't think those were the ones you aren't allowed to post due to number of characters). Otherwise, try to attach the file instead. Quote
