PheiaOenix Posted December 11, 2006 Posted December 11, 2006 Well I'm having this hard time on how to create a Hip Roof Plan...I found out from the previous post w/c was closed, that it can be done by EXTRUSION...but it might be tricky, someone said. Well I want to know the process of doing it, or if there's other way to do it without using EXTRUSION...you might as well state it here.....:D BTW I'm using AutoCAD 2005...hope to hear some of your ideas....thanks in advance:D:D Quote
LSR Posted December 11, 2006 Posted December 11, 2006 Well I'm having this hard time on how to create a Hip Roof Plan...I found out from the previous post w/c was closed, that it can be done by EXTRUSION...but it might be tricky, someone said. Well I want to know the process of doing it, or if there's other way to do it without using EXTRUSION...you might as well state it here.....:D BTW I'm using AutoCAD 2005...hope to hear some of your ideas....thanks in advance:D:D The other way of doing it is 3D surface (not a solid) Here how; Four Sided Faces Command: 3dface Specify first point or [invisible]: 0,0,0 Specify second point or [invisible]: 10,10,10 Specify third point or [invisible] : 40,10,10 Specify fourth point or [invisible] : 50,0,0 Specify third point or [invisible] : return 3 Sided Faces Command: _3dface Specify first point or [invisible]: 0,0,0 Specify second point or [invisible]: 10,10,10 Specify third point or [invisible] : 0,20,0 Specify fourth point or [invisible] : Specify third point or [invisible] : return Four Side Faces Command: _3dface Specify first point or [invisible]: 0,20,0 Specify second point or [invisible]: 10,10,10 Specify third point or [invisible] : 40,10,10 Specify fourth point or [invisible] : 50,20,0 Specify third point or [invisible] : return 3 Sided Faces Command: _3dface Specify first point or [invisible]: 50,0,0 Specify second point or [invisible]: 40,10,10 Specify third point or [invisible] : 50,20,0 Specify fourth point or [invisible] : Specify third point or [invisible] : return Quote
BIGAL Posted December 18, 2006 Posted December 18, 2006 Have you tried pface it can have multiple points in it but must be in one 3d plane and yes definately works for 3D roofs, wrote Hip gable valley years ago in lisp Quote
iain9876 Posted December 18, 2006 Posted December 18, 2006 is a hip roof ...just a simple plain "trendy (cool)roof" that isn't dull in any way? Quote
LSR Posted December 18, 2006 Posted December 18, 2006 is a hip roof ...just a simple plain "trendy (cool)roof" that isn't dull in any way? No it is not a "trendy (cool) roof" name, it's actually one of roof truss system in Architecture. I think the word "hip" came from the part of the roof called "girder" many carpenter called it hip ginder. And what is a girder you say? It is a long horizontal beam support of the structure. Quote
iain9876 Posted December 18, 2006 Posted December 18, 2006 No it is not a "trendy (cool) roof" name, it's actually one of roof truss system in Architecture. I think the word "hip" came from the part of the roof called "girder" many carpenter called it hip ginder.And what is a girder you say? It is a long horizontal beam support of the structure. ! I don't believe you actually answered that .....read my post 10 times and see if you get it.....for cryin out loud.....! Quote
LSR Posted December 18, 2006 Posted December 18, 2006 !I don't believe you actually answered that .....read my post 10 times and see if you get it.....for cryin out loud.....! Oh yeah............got it!!!! BTW.....Merry Christmas to you too!! Quote
iain9876 Posted December 18, 2006 Posted December 18, 2006 Oh yeah............got it!!!! BTW.....Merry Christmas to you too!! lol, thanks you have a good one too Quote
neyoski11 Posted January 1, 2009 Posted January 1, 2009 i prefer usinng the slice command........u have to extrude the boundary of the roof and make it a box the u slice alon the planes to get ur slopes.the slice command is one of the most essential tools in auticad 3d modelling Quote
