This is the macro I have written for turning off multiple layers. It does not work....thoughts?
^C^C_-LAYER;OFF;SHADE*;OFF;M-HVAC*;OFF;E-*;OFF;D-*;OFF;A-GLAZ*;OFF;A-MILW*;OFF;A-PFLR*; OFF;A-TEXT*;OFF;P-*;OFF;A-DOOR*;OFF;A-FLOR*;OFF;A-CLNG*;OFF;A-KTCH*;OFF;A-SCHD*;;
Thanks
BA
At what point does the macro cease to function?
Would the asterisk be a wildcard?
yes.........and the ;; ends the string
also...for whatever reason some layers or strings do work or turn off when the command is invoked. (shade*, E-*, A-MILW-*) turn off, the rest do not?
If you could post a file here with all of those layers in it I can figure it out for you.
there are hundreds of layers. The syntax is typical AIA nomenclature...i.e A-DOOR-FULL-INTR...or (A-Door-*) in my string...* being the wildcard.
Can you put a file with one of each typical layer here? I already know that * is a wildcard. I just want to see if I can fix the problem for you.
The problem is the "-" in the name, can you get rid of that ?
or at least change the macro to *door* without losing functionality of your macro,
A-MILW-* works. A-DOOR-* does not?
Got it.....Steven-G. You got part of it and I had a space between an off in the string. Here is the working string...
^C^C_-LAYER;OFF;SHADE*;OFF;M-HVAC*;OFF;E*;OFF;D-DEMO*;OFF;A-GLAZ*;OFF;A-MILW*;OFF;A-PFLR*;OFF;A-TEXT*;OFF;P-FIXT*;OFF;A-DOOR*;OFF;A-FLOR*;OFF;A-CLNG*;OFF;A-KTCH*;OFF;A-SCHD*;OFF;A-FURN*;;
Yup spotted it, It is usually something simple like that. Well done
Wow, I checked for spaces too and didn't see any... It's pretty hard to pick em out but I see it now that I looked even closer.
Thanks all. I use this macro in conjunction with my layering which I have "On Screen" each layer is in a toolbar (several) "on" "off" and I have a tool bar that has "wildcard" layers on and off. This button turns off multiple layers in different items (architectural, structural, texts, etc.) for editing different parts of a drawing. In this case specific to roof framing. I find it quicker and easier than layer filters.
Good idea, I can use that, I use filters a lot but macro's might be easier.
I use dual monitors. I grew up on a digitizer tablet with multiple menu overlays. When windows went graphic, I replaced the digitizer with a monitor and put all of my commands on it just as my digitizer used to. I virtually have any and all commands on screen along with all of my layering. Very fast. I was really pissed when ACAD 14 came along!!!!
