CL Seals Posted January 9, 2014 Share Posted January 9, 2014 I am using Autocad 2006. I imported a surevy document to us in developing a site plan. I am experencing problems with my fillet command. I went to express tools to the flatten comand but that did not help. I then went to options,Drafting, object SnapOptions and activated "repalace Z value with current elevation. That did not help. Is there a solution to my problem? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 10, 2014 Share Posted January 10, 2014 1. Did you check the objects have all z values as 0 ? 2. If you fillet say two lines and 1 is to short, fillet will not work. Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 10, 2014 Share Posted January 10, 2014 We might be able to diagnose the problem better if you were to attach a sample drawing to a subsequent post. Entirely up to you. Quote Link to comment Share on other sites More sharing options...
