potencjalek Posted January 12, 2014 Posted January 12, 2014 i try to export data do external application from Autocad i have one problem i cannot create proper null character for that file i need null character for determine end of string in that file function (write-line (strcat "text" (chr 256))) doesn't create null sign on the end of line attached file i want to create (please open it by notepad++ to see null character) is it possible to create such a file by lisp? null_charakter.txt Quote
Lee Mac Posted January 12, 2014 Posted January 12, 2014 Try the following [color=GREEN];; Null Character Example by Lee Mac 2014-01-12[/color] ([color=BLUE]defun[/color] nullchartest ( str txt [color=BLUE]/[/color] fso stm ) ([color=BLUE]if[/color] ([color=BLUE]setq[/color] fso ([color=BLUE]vlax-create-object[/color] [color=MAROON]"scripting.filesystemobject"[/color])) ([color=BLUE]progn[/color] ([color=BLUE]vl-catch-all-apply[/color] '([color=BLUE]lambda[/color] ( ) ([color=BLUE]setq[/color] stm ([color=BLUE]vlax-invoke[/color] fso 'createtextfile txt -1 0)) ([color=BLUE]vlax-invoke[/color] stm 'write ([color=BLUE]strcat[/color] str ([color=BLUE]chr[/color] 256))) ([color=BLUE]vlax-invoke[/color] stm '[color=BLUE]close[/color]) ) ) ([color=BLUE]if[/color] ([color=BLUE]=[/color] 'vla-object ([color=BLUE]type[/color] stm)) ([color=BLUE]vlax-release-object[/color] stm) ) ([color=BLUE]if[/color] ([color=BLUE]=[/color] 'vla-object ([color=BLUE]type[/color] fso)) ([color=BLUE]vlax-release-object[/color] fso) ) ([color=BLUE]findfile[/color] txt) ) ) ) ([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color]) Test program: ([color=BLUE]defun[/color] c:test ( ) (nullchartest [color=MAROON]"line-text"[/color] ([color=BLUE]vl-filename-mktemp[/color] [color=MAROON]"test"[/color] ([color=BLUE]getvar[/color] 'dwgprefix) [color=MAROON]".txt"[/color])) ) Quote
BIGAL Posted January 13, 2014 Posted January 13, 2014 When you write a normal line of text if you hex dump it it will actually have two codes as end of string OD & OA this is carriage return & line feed. Can you not check for these codes if your reading the file like a database and 1 character at a time. If I remember correct is (chr 13) Quote
potencjalek Posted January 13, 2014 Author Posted January 13, 2014 Try the following [color=GREEN];; Null Character Example by Lee Mac 2014-01-12[/color] ([color=BLUE]defun[/color] nullchartest ( str txt [color=BLUE]/[/color] fso stm ) ([color=BLUE]if[/color] ([color=BLUE]setq[/color] fso ([color=BLUE]vlax-create-object[/color] [color=MAROON]"scripting.filesystemobject"[/color])) ([color=BLUE]progn[/color] ([color=BLUE]vl-catch-all-apply[/color] '([color=BLUE]lambda[/color] ( ) ([color=BLUE]setq[/color] stm ([color=BLUE]vlax-invoke[/color] fso 'createtextfile txt -1 0)) ([color=BLUE]vlax-invoke[/color] stm 'write ([color=BLUE]strcat[/color] str ([color=BLUE]chr[/color] 256))) ([color=BLUE]vlax-invoke[/color] stm '[color=BLUE]close[/color]) ) ) ([color=BLUE]if[/color] ([color=BLUE]=[/color] 'vla-object ([color=BLUE]type[/color] stm)) ([color=BLUE]vlax-release-object[/color] stm) ) ([color=BLUE]if[/color] ([color=BLUE]=[/color] 'vla-object ([color=BLUE]type[/color] fso)) ([color=BLUE]vlax-release-object[/color] fso) ) ([color=BLUE]findfile[/color] txt) ) ) ) ([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color]) Test program: ([color=BLUE]defun[/color] c:test ( ) (nullchartest [color=MAROON]"line-text"[/color] ([color=BLUE]vl-filename-mktemp[/color] [color=MAROON]"test"[/color] ([color=BLUE]getvar[/color] 'dwgprefix) [color=MAROON]".txt"[/color])) ) works perfectly for me thank you very much i think its time to donate your website Quote
potencjalek Posted January 13, 2014 Author Posted January 13, 2014 one more question i tried to change little bit your function to write more then one line (defun nullchartest ( str txt / fso stm ) (if (setq fso (vlax-create-object "scripting.filesystemobject")) (progn (vl-catch-all-apply '(lambda ( ) (setq stm (vlax-invoke fso 'createtextfile txt -1 0)) (vlax-invoke stm 'write (strcat str (chr 256))) (vlax-invoke stm 'write (strcat "text for line 2" (chr 256))) ;;;;;changes (vlax-invoke stm 'close) ) ) (if (= 'vla-object (type stm)) (vlax-release-object stm) ) (if (= 'vla-object (type fso)) (vlax-release-object fso) ) (findfile txt) ) ) ) but in results it write only one (first) line, why is that? Quote
potencjalek Posted January 14, 2014 Author Posted January 14, 2014 ok, topic closed i figured it out i forgot about (vlax-invoke stm 'write (chr 10)) ;;; starting next line between lines thanks you all for help Quote
Lee Mac Posted January 14, 2014 Posted January 14, 2014 works perfectly for methank you very much i think its time to donate your website Excellent, I'm glad it works as required. Thank you also for your kind offer of a donation, I appreciate it but in results it write only one (first) line, why is that? As you have gathered, a carriage return & line feed are required for a new line: ;; Null Character Example by Lee Mac 2014-01-14 (defun nullchartest ( txt / fso stm ) (if (setq fso (vlax-create-object "scripting.filesystemobject")) (progn (vl-catch-all-apply '(lambda ( ) (setq stm (vlax-invoke fso 'createtextfile txt -1 0)) (vlax-invoke stm 'write (strcat "This is line 1" (chr 256) "\r\nThis is line 2" (chr 256) ) ) (vlax-invoke stm 'close) ) ) (if (= 'vla-object (type stm)) (vlax-release-object stm) ) (if (= 'vla-object (type fso)) (vlax-release-object fso) ) (findfile txt) ) ) ) Quote
