hldman Posted January 13, 2014 Share Posted January 13, 2014 hello everybody, i am a learner of 3ds max, and i am learning compound loft function. what i am trying to build is a mouse model. i drew the cross-section shape of the mouse and a path, then i loft the shape along the path. Another 2 shapes are used to fit the loft object. BUT, sth went wrong , look at the pic below: why is the rear part of the mouse like that? what should i pay attention to when Lofting and Fitting? thanks a lot. Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 14, 2014 Share Posted January 14, 2014 Can you export the drawing in a DWG format and attach it to your next post? Quote Link to comment Share on other sites More sharing options...
Cad64 Posted January 14, 2014 Share Posted January 14, 2014 What tutorial are you following? Take a look at this one: http://www.hallofheads.com/tutorials/tut7.htm I realize you're trying to learn how to use the Loft tool, but if I was going to create a mouse, I would do it using NURMS Subdivision. Quote Link to comment Share on other sites More sharing options...
hldman Posted January 15, 2014 Author Share Posted January 15, 2014 thank u, cad64 Quote Link to comment Share on other sites More sharing options...
