Need Auto numbering LISP sorting by distance
Hi all,
Very new at this forum. I need an AutoLISP that will help me auto numbering blocks or text. I am aware of "TCOUNT which is handy, however the command only gives you 3 choices in regards to how to number, X, Y and Select order. What I need is a program that will sort and number my blocks/text by distance from a point. Thank you so much for your help.
Link to post
Welcome to CADTutor :)
Try this code which should deal with Blocks and let me know how you'd get on with it .
Note : if the text height is not suitable for you , you can change it from one to as indicated in the code .
(defun c:Test (/ ss pt i sn p l lst n)
 (if (and (setq ss (ssget '((0 . "INSERT"))))
          (setq pt (getpoint "\n Specify Center point :"))
       (setq sn (ssname ss (setq i (1- i)))
             p  (cdr (assoc 10 (entget sn)))
             l  (cons (list (distance pt p) p) l)
     (setq lst (vl-sort l (function (lambda (j k) (< (car j) (car k)))))
           n   0
     (foreach x lst
       (entmakex (list '(0 . "TEXT")
                       (cons 10 (cadr x))
                       (cons 11 (cadr x))
                       (cons 1 (itoa (setq n (1+ n))))
                       (cons 40 1.0) ; Text height
Link to post
David, your observation is correct, except that Tharwat's code isn't sorting atoms, but lists, and those will be preserved after sorting, even if identical.
Link to post
