gsksun4 Posted January 20, 2014 Posted January 20, 2014 I have an old version of AutoCAD R14 I still use for certain things. Suddenly for no apparent reason, when I start up AutoCAD I get an error message "Error Loading Dialog Control File". I have back-up .pgp, .mnu support files on CD that I tried to copy over the existing in my support directory, but I've lost all my hot keys commands. I rebooted and still get this error message. Anyone familiar with this? Glenn Quote
rkmcswain Posted January 20, 2014 Posted January 20, 2014 Most likely thing is either the support paths have been changed -or- the files it's looking for have been moved. See also: http://forums.autodesk.com/t5/forums/searchpage/tab/message?filter=labels%2Clocation&location=forum-board%3A15&q=Error+Loading+Dialog+Control+File Quote
gsksun4 Posted January 20, 2014 Author Posted January 20, 2014 Most likely thing is either the support paths have been changed -or- the files it's looking for have been moved.See also: http://forums.autodesk.com/t5/forums/searchpage/tab/message?filter=labels%2Clocation&location=forum-board%3A15&q=Error+Loading+Dialog+Control+File That's exactly what happened. Thanks for the link R.K. Also I had the IT dept. do a "System Restore" and that helped as well. Glenn Quote
