PRA3889 Posted January 21, 2014 Posted January 21, 2014 how to trim all lines inside the circle in only one step in auto cad 2013 Drawing2.dwg Quote
BIGAL Posted January 21, 2014 Posted January 21, 2014 (edited) No code but make a list of circles entname then loop, trim ent1 cen pt circle manually works. this is close (defun ah:trimcirs ( / x obj ss) (setvar "osmode" 0) (setq ss (ssget (list (cons 0 "Circle")))) (setq x 0) (repeat (sslength ss) (setq obj (ssname ss x)) (setq cenpt (cdr (assoc 10 (entget obj)))) (command "trim" obj "" cenpt "") (setq x (+ x 1)) ) ) (ah:trimcirs) Edited January 21, 2014 by BIGAL Quote
nestly Posted January 21, 2014 Posted January 21, 2014 Since it's a constant pattern, perhaps use an ARRAY? Quote
ReMark Posted January 21, 2014 Posted January 21, 2014 The lisp routine in the link to the thread below by forum member irneb will trim out the lines in all the circles. See post #8. http://www.cadtutor.net/forum/showthread.php?68144-how-trim-many-line-inside-multi-circle-on-one-step&p=467090&viewfull=1#post467090 Quote
pBe Posted January 22, 2014 Posted January 22, 2014 Make a Break.... (Defun c:demo (/ cir lin cirline e int) (if (setq cir nil lin nil cirline (ssget '((0 . "CIRCLE,LINE"))) ) (progn (repeat (sslength cirline) (setq e (ssname cirline 0)) (if (eq (cdr (assoc 0 (entget (setq e (ssname cirline 0))))) "CIRCLE") (setq cir (cons (vlax-ename->vla-object e) cir)) (setq lin (cons e lin)) ) (ssdel e cirline) ) (foreach itm lin (if (and cir (setq int (vl-some '(lambda (x) (if (setq hit (vlax-invoke (vlax-ename->vla-object itm) 'intersectwith x acExtendNone )) (list x hit) ) ) cir )) (= (length (setq pts (cadr int))) 6) ) (command "_break" itm "_non" (list (car pts) (cadr pts)) "_non" (list (nth 3 pts) (nth 4 pts))) ) ) ) ) (princ) ) Quote
