Sluman Posted January 22, 2014 Posted January 22, 2014 I've seen this used in CAD, but am curious specifically what it represents. I couldn't find an answer in Help. What does the @ symbol represent when typed at the command line in AutoCAD? Quote
Tiger Posted January 22, 2014 Posted January 22, 2014 If you search in Help for Relative and Absolute coordinates, then you'll find the @-symbol. If I remember correctly, if you type the @-symbol before a set of coordinates, you are given a set of relative coordinates. Respectivly, if you put a #-sign before the coordinates, they are interpreted as absolut. It depends on what the pre-set option is which is connected with the setting of the DYNMODE-variable if I am not mistaken. Quote
ReMark Posted January 22, 2014 Posted January 22, 2014 This should explain all the variations of the use of the symbol. http://www.ccadinc.com/autocad-tutorials-at-symbol.html Quote
SAFeSTeR Posted January 23, 2014 Posted January 23, 2014 Never knew this, can be quite handy. I know that when drawing some objects, like lines or arcs, when you reissue the command again, making a right click will automatically select the last point too, it doesn't work with circles though. Quote
PotGuy Posted January 23, 2014 Posted January 23, 2014 (edited) @ Can be used in certain AutoCAD commands, such as the line command. ie: 'Line' @200 @200 tells AutoCAD the distance of the line, and the So, you'd have a line drawn at 200 distance at a 40 degree angle. Edited January 23, 2014 by PotGuy It's <40, not <0! Quote
